F-100 brakes
Discussion in 'The Hokey Ass Message Board' started by rustyrods, Apr 22, 2011.
  1. rustyrods
    rustyrods
    from Dixon,Il.
    I have a set of 49 F-100 backing plates and drums. Does anyone know if these are the ones that fit 37 Ford spindles?
  2. Butch11443
    Butch11443
    Yup, their the right ones. You have to go to Speedway or one of the other ones to get the right bearing set to fit the 37 spindles.
    Butch
  3. I believe there is a tech thread in the archives that has the bearing, race, and seal numbers. Buy good bearings, not the cheap stuff.
  4. Mutt
    Mutt
    The original conversion was for '53-'56 F100, not Early F-1.
    I don't know if there is something new that I haven't seen for F-1s
    but here's the article and information on the changeover from the 90s. The bearings and parts are readily available at parts stores if you have the backing plates, hubs and drums from a '53-'56.
    Mutt
  5. Mutt
    Mutt
    This shows where to grind the kingpin boss for clearance.
    Mutt
