64 GTO Gasser
Discussion in 'The Hokey Ass Message Board' started by superchargedill, May 28, 2010.
  1. 55chieftain
    55chieftain
    Looking good Dil. Hell mine isn't even a real g***er, but i'm going to drive the hell out of it. I'm 2" over the crank centerline limit and will never be "legal", but it will still look alot better than the "donk" g***ers posted around here.
  2. lorodz
    lorodz
  3. superchargedill
    superchargedill
    Thanks Guys. Takin her to her first show this coming weekend at the Pontiac Nationals here in Tulsa just to show off how she looks so far. Way far from done but I don't care. It's been a lot of work and I'm havin fun building it with my boy.
  4. superchargedill
    superchargedill
    Not quite sure what to do with the grills. They are pitted pretty good but they are aluminum so I know they'll polish up descent. They look okay for now with the primer, but I know once I paint the car they will look pretty dingy.
    Anyone here have a preference for a good looking aluminum looking paint that might be better suited ?
    Rotten Johnny, Can you email me some pictures of your car. I'd like to see more of it and how you set it up. email me at superchargedill@yahoo.com thanks, Dil
  5. lockwoodkustoms
    lockwoodkustoms
    Now that is all kinds of MEAN!!!!!!!!!!!!.........
  6. Nuff said:cool:
  7. superchargedill
    superchargedill
    4/24, I just wasn't diggin the way the chrome center caps were lookin on the rear wheels. I was remembering seeing some flat type caps on some old race cars somewhere so I started looking around the net trying to find something for my wheels. Found some for $120.00. They look cool but too much for my wallet right now so I did the next best thing with my primitive tools.
    I pulled a piece of aluminum out of one of my s**** metal boxes and went to town. First I traced the base of the American center cap with a marker. Then stuck a drill bit in the mounting holes to mark where I needed to drill. Then cut the main shape out with my jigsaw. Next was grind some of the extra off with my 4" grinder with a sanding disc, then touch it up with the dremel with a sanding drum. Next I drilled the holes with a 3/16" bit in the drill press, then over the top of those holes with a 5/16" to get some bevel for the bevel allen head mounting screws. Took me about an hour to make 2 of them.
    What do you think ? Like'em better than the chrome caps or not ?
  8. twotoejoe
    twotoejoe
    Yea, they look better for your car. And you did well instead of paying $120!
  9. SOLO
    SOLO
    Looking good!
  10. superchargedill
    superchargedill
    4/26 got the rear shocks mounted so she's sittin on all 4's now. What do you think, sittin ok in the rear or does it need to be higher ?
  11. SmokinBill
    SmokinBill
    Looks right to me.... But i like'em alittle nose high!!!!!!!!
  12. 400 4spd.
    400 4spd.
  13. gasserjohn
    gasserjohn
    enjoy these photos
    i have another thread with info about it.....
  14. superchargedill
    superchargedill
    Cool pics. Thanks John
  15. superchargedill
    superchargedill
    4/28 I ordered a few pieces from MOON back when I picked up the car and got them installed tonight. 60's window crank, G***er style gas pedal, and custom cut the other pieces to fit the e brake and also cut down the size of the brake pedal. My friend Nick gave me the MOON tach which is now mounted up on top of the dash where it's easy to see. I had to add a plate to the back of the gas pedal for the roller wheel on the throttle mechanism to roll on. The entire throttle linkage works beautiful.
  16. enloe
    enloe
    from east , tn.
    that interior is awesome!!!!
  17. classic gary
    classic gary
    no stones but LOTS of aluminum:
  18. superchargedill
    superchargedill
    Hey Gary, Who makes that scoop?
  19. jalopyonlooker
    jalopyonlooker
    from Texas
    Looking good!
  20. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Rad car. Looks like a "real" g***er to me! Keep up the good work.
  21. superchargedill
    superchargedill
    4/30 Got the bumper on but the chrome was $hit so I hit the entire bumper with a 4" sanding disc to rough up the chrome so paint would stick. It turned out okay but I think the color I used looks like ****. Rustoleum Aluminum. It looks okay in the pictures but when you see it for real it doesn't look good at all. Definitely open for suggestions on a good silver that doesn't look like cheap chrome.
    This is the first time the car has seen sunlight since I brought her home last may. I trailered her down to Tulsa Raceway Park to show the Pontiac guys what I've been working on. There's still a lot of work, but making progress.
  22. classic gary
    classic gary
    i got it from: noahperformance on ebay.
    it ain't, um, perfect. you should probably stick with the one you've got, unless you want to trade !!;)
  23. superchargedill
    superchargedill
    Repainted the bumper with a better looking color. Here's a before and after look at it.
  24. superchargedill
    superchargedill
    5/2/11 Did a little fab and weld in the trunk area for the fuel tank and got it secured. Tonight I was working on the fuel lines and placement of the pump and filter.
  25. superchargedill
    superchargedill
    I did some more turning and made a heater delete plate.
    My boy and I repainted the front grills. I did one, he did the other. His turned out great too, no runs. Pretty good for an 8 year old shop hand.
    And I found another low beam T3 headlight so now I have a complete set.
    I also got the fuel pump, filter and lines all in and secured all the way up to the regulator at the back corner of the blower. Now I just need to finish up the carb lines tomorrow.
  26. daddylama
    daddylama
    damn this is turning into one cool goat...
  27. superchargedill
    superchargedill
    Thanks man. I'm having a blast just doing all kinds of things to be a little different. My Boy is 8 and he's been hanging out with me in the shop more and more so I get him to help me too. He painted the p***enger side grill the other night. Then I had him hold that delete plate from inside the car while I secured it from the engine compartment. Good thing I had him using the end of a hammer handle. Hit it twice with the screws. We were both laughing about that. obviously I wasn't going to chance zipping a screw into his hand.
  28. classic gary
    classic gary
    thought I'd add this picture to your collection. there was one posted earlier that looks close to this one, I like the no helmet and the smile.....
  29. superchargedill
    superchargedill
    Gary, that must have been taken while that car was still pretty new. You can see the rear inner wheel well is still white with only a little tire rubber. Thanks, Dil
  30. superchargedill
    superchargedill
    Here's a few pics from the Stray Kat 500 Show in Dewey last weekend.
