Which cam for my Flathead?
Discussion in 'The Hokey Ass Message Board' started by 1low51f1, Apr 25, 2011.
  1. 1low51f1
    1low51f1
    I have to pull my motor out, so while it is out I want to put a cam in. Any recomendations? I am looking at the Isky 88 or 77B. I am running a Fenton 2x2 intake, Eldelbrock Heads, and Fenton headers. It is a 50 8BA.
    thanks
  2. lonewolf
    lonewolf
    What kind of car, trans, rear end gear ratio?
  3. Hitchhiker
    Hitchhiker
    those types of factors can't have any effect on what to run :rolleyes:....Just put in the biggest stick you can find....:D
  4. 1low51f1
    1low51f1
    Sorry, 51 ford F1 pick up, stock rear, stock 3 speed, not sure on ratios
  5. hot rod rod
    hot rod rod
    Go isky.....it'll rip !!!!!
  6. tig master
    tig master
    from up north
  7. bobscogin
    bobscogin
    Got a Schneider 260º / .355 lift in my 99 Merc. Sounds and runs great on the test stand. Too bad my '29 rpu ain't finished yet.:(
    Bob
  8. speakfordadead
    speakfordadead
    I have a few Delong flathead cams... if you are interested i'll get you some numbers...
  9. flatmotor40
    flatmotor40
    from georgia
    I had Reed Cams grind me one It really great
