Whinning noise in TH350
Discussion in 'The Hokey Ass Message Board' started by bigalturk1, Apr 28, 2011.
  1. bigalturk1
    bigalturk1
    My 39' Ford with a small block and Turbo 350 started whinning (Like a Gear Driven cam) last week. It sounds like the Transmission. When it's in Neutral or Park there is no Whine, but it whines in gear...moving or not. Other than that it runs and shifts (Churps) good. The Trans is clean and full. I'm thinking it's the front pump or the "GER" 2400-2800 Stall converter. The trans has 15,000 non-abused miles over the last 20 years (More than I can say for myself).
  2. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Check the modulator ,Other than that Im at a loss
  3. FWilliams
    FWilliams
    mine did the same thing, it was the front pump.
  4. HotRodAV8
    HotRodAV8
    from Seattle Wa
    front pump,oil level,front pump could have loose bolts(old crooked ****** shops would back one or two off during a service and few months later ,****** makes noise they say needs rebuild. then brake clean case in car, retighten bolts big profit)
  5. gasserjohn
    gasserjohn
    plugged filter or pump ****ing air
    cheap fixs gets costly after this
    fix it now waiting may damage trans more
