49-54 chevy firewall mounted master cylinder questions.
Discussion in 'The Hokey Ass Message Board' started by Hot Rod Chris, Apr 28, 2011.
  1. Hot Rod Chris
    Hot Rod Chris
    Ok so I put some headers on my 54 chevy and now my pedals arm hits the header so now I have to redo my brake setup. I am going to keep it drums all the way around so I dont need a booster and just want to mount my master cylinder on the firewall. I know for the master I can use a late 60's dual master cylinder, but my question now is what about the pedal ***embely? I would like to keep it as simle looking as possible, what would you all suggest?
  2. R Frederick
    R Frederick
    from illinois
    I did a wilwood circle track dual master cylinder swinging pedal setup on mine when I had my 53. Got it used at a stock-car swap meet pretty cheap.
  3. 325w
    325w
    See can you find a 53-4 with power brakes. It will have a swinging pedal and a renforced plate to mount on the firewall.
  4. gasserjohn
    gasserjohn
    ansen type simple
    will mention again autozone rebuilt are sleeved by a large company in canada
  5. MJ mike
    MJ mike
    I used a setup from Walton Fabrication on my 53 tin woodie.
    It was awsome to install - bolt in and well engineered.
    They have kits for 48 - 54 chevys.
    www.waltonfabrication.com
  6. tb33anda3rd
    tb33anda3rd
    i used this type in a '54 buick. pedals had to be braced to keep them from bending sideways. the two '51's i did i used '70's camaro swing pedals they bolted to the firewall and the dash.
  7. T Weed
    T Weed
    Years back I had a 51 with a hanging pedal set-up from a 56 installed, as i recall it went in real easy...
  8. Hot Rod Chris
    Hot Rod Chris
    Do you all got any pics of u alls set up, im on a budget like everyone else here so im looking for a cheap setup to use. Like I said im going to keep it drums all around. Thanks
  9. Tri-five Chevy set up looks right in these and if I remember is a pretty easy swap.
  10. Hank
    Hank
    from Wisconsin
    You'll need a brace from the firewall to the dash. The stock firewall on my was not strong enough to take the peddle load. It flexed a lot.
  11. Hot Rod Chris
    Hot Rod Chris
    any pics?
  12. Tin Can
    Tin Can
    I set up one out of an s10 in mine. Plentiful and cheap and easy to find parts for. Got the entire brace from the firewall to the dash and put a thicker plate for the drivers side of the firewall. Mine is all tore apart now for finish work and paint so no pics
  13. My Buick with a TH400 is getting a pedal from a Aztek. Yeah, I know, but ugly is not catching.
    The pedal is a straight vertical mount for a flat firewall, the bolt pattern is the same as mid 90's Caprice and some GM pickups, and the boosterfrom the Caprice looks like it will fit the 78 master cylinder.
  14. mrconcdid
    mrconcdid
    from Florida
    I used an s10 set up but if you have the coin the walton kit is very nice
  15. chevsled53
    chevsled53
    from Australia
    I used a 55 chevy pedal in mine and was quiet easy to fit
  16. Chopp'd49
    Chopp'd49
    I used an ECI set up in my 49 Ford. It was easy to install and the guys were a great help.
  17. Hank
    Hank
    from Wisconsin
    Sorry no pics of mine. Used the ***embly from an S10. Used both the clutch and the brake peddle. Needed to modify the back to interface with the dash.
  18. outlawcuda
    outlawcuda
    from Wisconsin
    Have any of you seen where they used 2 clutch pedals from a S10s. ? Did you guys make your own linkage? The pins for the S10 clutch is a weird size.
