Projects update on the Model A Coupe
Discussion in 'The Hokey Ass Message Board' started by Paul, Sep 5, 2010.
  1. lowongas
    lowongas
    I have to admit one thing,when I first thought about the GOLD for an engine it made me sick.Now when I saw it all together...WOW...what a PERFECT color.Talk about nailing the stance AND the engine color.!!!!!!!!! I LOVE this coupe build..MORE..MORE...!!
  2. Paul
    Paul
    Editor
    the coupe is a slow build, hoping for a more finished end product,
    the roadster will be done a little less refined but I hope, sooner
    sometimes I wonder if either will ever be done,
    I seem to be easily distracted
    where your "Tuffy" is comming along at lightning speed!
    very fun to watch your progress
  3. Sparkswillfly
    Sparkswillfly
    from Colorado
    This build thread is awesome!
  4. hasty
    hasty
    Any progress over the holidays?
  5. Paul
    Paul
    Editor
    nice day, too nice not to make something for one of the projects
    thought maybe some headlight slash shock mounts for the coupe
    picked up a nice A headlight bar off craigslist,
    turned out the guy selling it was a freind and fellow HAMB member
    thanks Jeff!
    I had a couple F1 shock mounts already
    so I rolled the bench out in the sun and cut grind weld grind filed some nifty mounts just like they yousta
    follow along the pix speak for themselves
  6. Paul
    Paul
    Editor
    and then on to the other..
  7. Paul
    Paul
    Editor
    gotta round up some tubing to weld in the frame for through bolts to mount them but you get the idea..
  8. billthx138
    billthx138
    Made it look to easy...nice job.
  9. Boones
    Boones
    from Kent, Wa
    i like it.. nice job paul..
    you going to have the coupe ready for our pokerrun
  10. Dirty Dug
    Dirty Dug
    Why not just weld coupling nuts to the inside of the rails. Those two bolts are a ***** to get nuts on the inside with the spring in the way. looks nice Paul....
  11. cruzr
    cruzr
  12. general gow
    general gow
    MODERATOR
    nice work. i like those.
  13. Paul
    Paul
    Editor
    thanks Doug,
    I bent the mounts to clear the crossmember for just that reason
  14. Nice work, as usual.
  15. 50Delux
    50Delux
    from Michigan
    Very nice. And to think I had a headlight bar in my hand at a swap meet on Sat. Damn it I knew I should have bought it.
  16. BJR
    BJR
    I wonder.... will the headlights vibrate when you hit a bump, because of the shock mount? Please report back when it's on the road.
  17. Nice work. You can really get creative with with headlight stands and upper shock mounts. Part of giving your rod it's own personality.
  18. Paul
    Paul
    Editor
    when is it?
  19. Paul
    Paul
    Editor
    edit: threads merged
  20. hey man, that is one *****IN coupe! i hope you get it on the road with ease.
    I noticed you said you had trouble with cracked 371 blocks. did you buy them that way or did you crack them yourself? and were there suspect places they have cracked? i have one in my 58 olds and am just curious if there anything i should look for (or aviod power adding wise).
  21. Gregg Pellicer
    Gregg Pellicer
    I have a very simalar setup on my car. No vibration problem's at all
  22. 21tat
    21tat
  23. sko_ford
    sko_ford
    very cool man
  24. Malcolm
    Malcolm
    from Nebraska
    Nice work on your shock/headlight mounts... Gives me some ideas for mine.
    Thanks!
    Malcolm
  25. Paul
    Paul
    Editor
    wow, has it really been a whole year?
    rolled the coupe out of the corner yesterday
    started putting together some bracing for a new floor,
    and fit and tacked in both wheel wells
  26. Royalshifter
    Royalshifter
    Moderator
    Bad*** man....it looks as though it wants to pick a fight?
  27. Lowbuckboz
    Lowbuckboz
    Sweet looking coupe man!
