Re-Gluing shoe soles - need help!
Discussion in 'The Hokey Ass Message Board' started by HemiRambler, May 1, 2011.
  1. HemiRambler
    HemiRambler
    My nearly new RJS racing shoes are coming apart. They are a couple years old so they are in perfect shape other than the soles coming off like a banana peel.
    I've tried unsuccessfully to glue them back together.
    I used rubber cemement - and not sure where I went wrong. I used my tire patch file to roughen the surface, but the glue came right off first time I wore them.
    Any suggestions/tips?
    Obviously I can buy new shoes - it's just a shame to toss these otherwise perfect shoes and BTW they fit really really nice. Nice enough to want to fix them, but I hesitate to buy them again if all's I get is a dozen or so wearings out of them.
  2. Unkl Ian
    Unkl Ian
    Barge Cement is supposed to be good. Tandy carries it.
  3. daddio211
    daddio211
    Show-Goo. You can buy it anywhere. Use it outside though, it'll stink up the house.
  4. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
  5. 32 hudson
    32 hudson
    Correct spelling is Shoe Goo. Cost about 4 to 5 dollars a tube. It works great. I got it in the local hardware store.
  6. 500LBGorilla
    500LBGorilla
    from Austin Tx
    amazing goop..dumb name ,works great
  7. dragsterboy
    dragsterboy
    Shoe Goo.
    I work in a steel shop and use it on my work boots.Seems to be fire resistant.
    Shane
  8. CheaterRome
    CheaterRome
    from URANUS
    X 2 for the "Shoe-goo" used by the people most abusive to ANY shoe --------- Skateboarders.
    Your welcome.
  9. BuiltFerComfort
    BuiltFerComfort
    Also, Shoe-goo is the same thing as Plumbers Goop (purple label, packaged on blister pack) - that is easier to find around here since Home Depot and Ace Hardware carry it. (Made by the same company, same MSDS, looks and acts the same.)
  10. Redbows35panel
    Redbows35panel
    Good ole CONTACT CEMENT. Just did mine a couple of weeks ago. Show no signs of giving up again.
  11. gtkane
    gtkane
    Are these shoes traditional? If so, you will have to nail them on...
  12. FiddyFour
    FiddyFour
    i'd hesitate to take a chance on losing my feet in a fire, and buy new ones...
  13. OldsRanch
    OldsRanch
    I used the 3M weatherstripping adhesive, it was in the top of the toolbox nearby. Then I put the damn shoe in the vise, left it there overnight. Besides the vise-shaped dent, seems to be fine....
  14. Offset
    Offset
    from Canada
    I worked with a guy who had a similar issue. He glued the sole to the upper and decided it would be a good idea to put pressure on the joint until the glue tried. The shoe was firmly glued to his desk his foot was firmly glue to the shoe!! Still think it is funny thinking about it many years later
  15. Left Turn
    Left Turn
    from Omaha, NE
    SHOE GOO!!! works great for tore up sub woofer surrounds too... lol
  16. bluebrian
    bluebrian
    from dallas
    Master's or Barge shoe cement works great.
  17. c-10 simplex
    c-10 simplex
    Would using duct-tape being legal/would you be open to it? i've had great success with duct-tape even using it on jogging shoes.
