speedo wiring
Discussion in 'The Hokey Ass Message Board' started by Jimv, May 3, 2011.
  1. Jimv
    Jimv
    helping someone wire a 31/flatty PU & it has a "cl***ic instrument" 0-140mph electronic speedo with no wiring diagram.The terminals on the back have at "noon" a lite with 2 wires, at "two O'clock" a "GRN"(ground) at "three" theres one with "1 2 3", a little below center a terminal with "SIG",at "six" theres a "DIP" switch panel with numbers "1-12" & at "nine"there a terminal with "B+" next to it a a "A" below it.
    On the trans sender unit theres Three wires that are "black" "red" & "clear".
    Can anyone either explain what gets hooked up where or post a wiring diagram on here, thank you
    JimV
  2. propwash
    propwash
    from Las Vegas
    Call Cl***ic Instrument's tech department, ask them to email you a diagram for that particular model.
  3. ford1932
    ford1932
    from Canada
    On the sender (hall effect) black should be grd, red +, clear is the signal
    Speedo grd - ground, sig signal from sender, b+ battery + from ign switch, two wires for lighting
  4. Gator
    Gator
    from Statham Ga
  5. Jimv
    Jimv
    Thanks for the help everyone, worked out perfect.
    jimV
