Bending a shift lever (gun barrel)
Discussion in 'The Hokey Ass Message Board' started by Jimmy2car, May 3, 2011.
  1. Jimmy2car
    Jimmy2car
    from No. Cal
    I need a bit of advice. I'm using a rifle barrel as a shift lever. It's mated to a Jeep transmission shifter. I'm using the rifle barrel because it's got the hole in it and I can run wires inside it to trigger the overdrive on my car. The shift ball has a switch, so everything is hidden. I'd like to bend it sorta like a 32 Ford shift lever, or, just make a gentle bend in it. I've used heat to bend spindles for a dropped axle, etc., but am not sure how to do this. Any advice is appreciated. I realize I may have to cut it again to accomplish this.
    Here's a couple of pictures of the thing
    Thanks
    Jim
  2. RichG
    RichG
    I would mark out the bend I want on a steel table, weld posts to bend against, and then heat the barrel like you did your spindles, bend to posts... I don't think it would be any more difficult than that.
  3. 50dodge4x4
    50dodge4x4
    Be sure to heat the entire diameter of the tube, and bend it very slowly or the tube will kink. A long slow curve will be easier then a sharp bend, unless a kinked tube will not be an issue for you. Gene
  4. stainlesssteelrat
    stainlesssteelrat
    from ms
    naaww.. he likes em *****.
  5. Jimmy2car
    Jimmy2car
    from No. Cal
    Well, not the shift lever
  6. 55 dude
    55 dude
    call a gunsmith they could probably suggest proper way to bend gun barrel.
  7. just make sure theres no bullets in it when you heat it:eek::D
  8. Fe26
    Fe26
    Why would a gunsmith know how to bend a rifle barrel?:D
    Unless he was in the business of making rifles to shoot kangaroos:cool:
  9. tb33anda3rd
    tb33anda3rd
    i've heard of guys filling tube with sand and closing up the ends prior to heating and bending to prevent kinks.
  10. AssGasket
    AssGasket
    What caliber...??? If it's a .22,, the bore diameter probably won't affect the outer dimensions that much when bent... They tend to have heavy barrels anyway...
    Just wondering, what is the barrel originally from..??? Usually,, **** like this ends up happening to the rarest and most desirable gun parts....
  11. Tap a peice of wooden dowel into one end, use dry sand and ram it in the tube then plug up the other end with another dowel, this effectivly makes it a solid objet and it will not kink. Ive bent 3/4 s.s tube into 1 foot coils this way and never had a failure.
    Hope this helps mate.
    Jason.
  12. co_sniper
    co_sniper
    from ohio
    go to your local autoparts store buy a spring that goes over a break line put it inside the barrel and it wont kink bend it and then take your spring out disturbing that you are going to mess up a gun barrel but it will bend right like that good luck
  13. Lucky3
    Lucky3
    X2...Sand works really well but the bend shown in the picture is REALLY a sharp bend. Just go slow and easy. Closing or sealing the ends is the trick BTW. Why not just use moly tubing ? Happy motoring.
  14. REM/Mo
    REM/Mo
    from Missouri
    A gun barrel is a little different than tubing. I don't think you will have any problem with it kinking unless you make a severely sharp bend.
    Just heat it evenly and bend it gradually.
  15. BOWTIE BROWN
    BOWTIE BROWN
    x2...i think the gauge of metal will not kink or whatever.
    "and the bowtie rolls on"
  16. norms30a
    norms30a
    Sounds like a cool idea, but I thought there would be some :::shoot, I've been blasting through gears until my arm is shot::: jokes :D
  17. Zeke
    Zeke
    We wouldn't. I've had to change a a few bent barrels but never was asked to bend one..
  18. R Frederick
    R Frederick
    from illinois
    Ha ha, come on - really?
  19. Jimmy2car
    Jimmy2car
    from No. Cal
    Thanks for all the help.
    It's a Marlin Model 60 .22 cal barrel that I bought for $12.00 Don't think it is/was anything rare. Just wanted NOT to have wires running down the side of the shift lever. The shift ball is from a Volvo and it slides onto splines at the top. The four speed shift pattern for reverse is wrong, but I don't think anyone will notice
    Jim
  20. DrJ
    DrJ
    A heavy lever like that might tend to pull/yank it out of gear during acceleration or braking.
    You might want to rethink this idea.
  21. Jimmy2car
    Jimmy2car
    from No. Cal
    DrJ
    It's really no heavier than a stock shift lever.
