I'm wanting to know what seats work good for the 60's p/u? The seat in mine is shot and wanting to know what fits! Thanks in advance guys! Sent from my iPhone using TJJ
You may have to section the bases a bit though as the later model seats seem to sit quite a bit higher than the earlier seat did. Go for the later seats with some shaped support in them as I had an 88 base level seat in the 71 and it looked great but wasn't too comfortable. I have an early 90's split bench in it now and it really sits comfortable. But it could be an inch or so lower as I look out the windshield a lot higher than I used to.
late 80's early 90's are the best IMO ..two holes line up....you sit just a little lower compared to orginal seats
I know this thread might be bit out dated but could you explain a bit more on what you mean by more leg room? better yet any body have pics of these seats installed on a 60-66 c-10
The 88 and newer GM pickup seat platform is a tad lower than the factory bench seat and the upholstery holds the occupants lower in the seat when installed in a 60-66 application. I have 100k miles of knowledge on that. Car bucket seats in this truck cab are too low if bolted directly to the floorboards. They **** after many miles. I have 75k miles of knowledge on that. The factory seat is ok at best. Barely. Yep, 25k miles of knowledge with that. I stand 5'7", so my comfort basis is in my 30" inseam length. My comfort basis is also from driving home after performing a very physical job for years on end and truck miles on end. I hurt more from climbing out of a stone stock 87 Nissan Sentra after a hard day of work and then the 40 mile drive home vs my ragtag 65 Chevy pickup with a 89 GMC non-headrest bench worn out seat. My DD is a 96 Chevy stock 1/2 ton 4wd. If it gets plowed, I know where the split bench will go. I've had my Black Dog 65 Chevy since 86. The Black Dog will roll down the road again one day.
I used a 73-87 chevy seat, took the brackets off and the 63 brackets bolted right to it, no drilling, no problems... the only thing that ****ed was right after the seat went in I needed to change the sending unit in the tank, and the seat I installed did not fold forward.
Hello everyone, new to the c10 world and to this site. I was hoping to get some needed help with this issue im having. I have a 64 c10 short step with no seat currently in it. I was given what appears to be an 88-94 60/40 split bench and I'm wondering if anyone has done this before, or has it only been the full bench. It has 2 of the tall risers on driver side seat and 1 on p***enger side seat. But the other riser on the p***enger side seat is shorter and the seat leans to the middle of the cab. Sorry if this has already been talked about but I'm new an I'm trying to navigate the site for my research. I've added 2 pictures to help understand what i mean by the 2 different mount i have on the same seat. Thanks in advance for any help that can be given. Pictures would be very helpful
I have a 1960 parts truck that I believe has a 60/40 like you describe in it. I can try to remember to look how they mounted it.
We used to adapt GTO buckets to them, this is 1975 technology and probably not wise now that I look back on it. We used 4" x 4" pieces of lumber, counter-bored holes in them and attached them to the floor. Then lagged the seats into the wood. Luck was with us, no accidents. If I had to do buckets again, I'd look to make the risers out of c-channel steel.
