**tachometer help**
Discussion in 'The Hokey Ass Message Board' started by lesabre59, May 9, 2011.
  1. lesabre59
    lesabre59
    Removed the bucket, it has a 4,6,8 cyl selector. The front face has "Made in the USA" on the bottom and no other markings. Any idea who the manufacturer is? Since it only has 2 wires im ***uming it requires a sending unit? Especially since one of the wires is a light.
  2. Da Tinman
    Da Tinman
    uh,, we need pics.
  3. lesabre59
    lesabre59
    ooops, here the pic
  4. Tenacious A
    Tenacious A
    from Willis Tx
    No sending unit required. Looks like an old sun brand.
  5. lesabre59
    lesabre59
    So one wire to "tach" on HEI and the other a switched hot? Do the ground come from the body/column?
  6. Tenacious A
    Tenacious A
    from Willis Tx
    Yup, you got it
  7. Uh I am seeing 4 wires not two. Rwed to switched power, green to the tach supply either the coil or in your case the Tach terminal on your hei. That leaves two wores to deal with for the light and the ground, black would be my choice for ground but I am not seeing black so whatever wire supplies the light is not the ground the other is.
  8. lesabre59
    lesabre59
    Actually there are just 2 long wires, its rolled around in the pic.
  9. lesabre59
    lesabre59
    bump for the afternoon crowd
  10. OK now I see it. Sorry for the bad advice.
  11. cac646
    cac646
    Just picked one of these tach's up at a swap meet. Anybody know if it will work with a Petronix ignition? Would the wiring still be the same as described above?
  12. squirrel
    You'd wire it to the negative side of the coil. Try it, see what happens. Make sure you ground the tach body to the car.
  13. F-6Garagerat
    F-6Garagerat
    Kinda looks like an "Airguide" marine tachometer.
  14. Larry T
    Larry T
    Maybe a Faria (mid 60's), seems like they looked like that and had a two wire hookup.
    Larry T
  15. slowmotion
    slowmotion
    I remember having a very similar one in my Valiant years ago. Maybe an unbranded R A C?
  16. cac646
    cac646
    tried hooking this up to my hot rod with an accurate tach and it seems to respond very slowly and doesn't seem to get up to the correct rpm. Seems to read correct at idle but moves very slow.
    Any ideas as to what might be wrong?
  17. 14Hotrods
    14Hotrods
    I have a tach that looks just like yours. Made in USA, on it. No other markings, and only 2 wires. I wired one to the "tach" position on the HEI. The other came from the light bulb. I mounted on metal dash so ***umed the tach housing was grounded there. Mine works like that.
  18. cac646
    cac646
    It sounds like I'm having trouble with the tach due to my Pertronix Ignition - apparantly the electronic ignition doens't have enough juice to power the tach??
    Does anybody know if one of the MSD tach amps can be used to boost the signal??
