Butt weld clamps
Discussion in 'The Hokey Ass Message Board' started by Dale Fairfax, May 2, 2011.
  1. BERNIES WELDING
    BERNIES WELDING
    those clamps are fine for certain applications, the main problem is the gap that is there and those that are not very experienced in welding should look into a pneumatic tool that is sold thru places like harbor fright, east woods and i have seen them sold at car shows. this tool will form a lip that is equal to the thickness of the material that bodies are made from and you will have a backing strip under your joint in the form of a lap joint. this took also has the capability of punching holes in the lip that gose over the top so the joint can be plug welded like a spot weld and then there is less chance to have warping when the pieces sre fitted together i ude kleikos they are a tool that is used in the aircraft industry and they act like a rivet and hold your pieces in place and from there you know what your exact fit will look like and go from there.
    unless you are a master at welding sheetmetal together in a **** joint set up it will fight you and the frustration factor goes off the scale.
    good luck with those.
  2. jhnarial
    jhnarial
    from MISSOURI
    That is terrible advice. Sorry but I had to say it:eek: ,as for the clamps I have been welding in panels for a long time and have never found the need for them.Gap is way to big even forMIGg but that is just my opinion.
  3. OLLIN
    OLLIN
    cool, just bought 2 sets on ebay..
    I was just planning to go check for these at HF.
  4. fleet-master
    fleet-master
    ..what about magnets? or simply leaving a small series of tabs on one of the sheets ? works for me.. as does long reach vice grips with flat 'feet' on 'em
  5. Da Tinman
    Da Tinman
    you should never lap weld sheetmetal. the seam will hold moisture and will rust very quickly, it will also be impossible to stretch the weld back to shape. **** welding is the only correct way to do the job.
  6. bonez
    bonez
    from Slow lane
    Now this is useful!
    Where i live nobody has a clue when i describe this tool, even pro welding shops, which i find incredible btw, i been thinkin of making the square ones for sometime, but this style look way easier for the backyard mech.
  7. tinsled
    tinsled
  8. Texas57
    Texas57
    I'm a novice mig welder, but one thing I did figure out is that magnets too close to the mig welding area will interfere somehow with the welding process.
  9. john~N~dallas
    john~N~dallas
    Why not use clecos and a few strips of steel.. This is what I have been doing ever since I saw these pics here on the hamb works like a charm
    ImageUploadedByTJJ1361294398.713774.jpg ImageUploadedByTJJ1361294418.259184.jpg ImageUploadedByTJJ1361294460.380866.jpg
    Taken from here from .. Guy who made is 4dr shoebox into a 2dr
  10. volvobrynk
    volvobrynk
    from Denmark
    This might be a dumb question; how the "beep" do you get them out afterwards?
    I might be a dumb ****, but it will only work on stuff where you can reach the backside?
    The cleco looks more like something that i could use, but that is only for stuff you lap?
    Is there ar DIY Cleco?
  11. willymakeit
    willymakeit
    Lossen the wing nut ,tap the pin out on the back side ,remove the clamp. Not for blind areas without acess unless you dont mind losing the pin.
  12. I drilled holes for mech wire, so I cud retrieve 'em after
  13. moparmuscle1
    moparmuscle1
    Nice John , never thought of them that way before . Learned something new today
  14. Mr48chev
    The pins actually come out pretty easily but usually the clamp get used on panels that you have some access to the back side anyhow.
    I don't think it would be productive to make your own clecos but they are readily available from a lot of sources including aircraft surplus stores, tool supplies that cater to aircraft work and ebay. You do need the pliers that go with them to use them though. This Ebay add has 50 clecos and a pair of pliers for 38.95 and there are dozens of similar adds for them. 190628766805
  15. Hemi j
    Hemi j
    from Colorado
    I bought some last week at HF but haven't tried them yet!
  16. stovebolt62
    stovebolt62
    This is the best idea on the thread.
  17. john~N~dallas
    john~N~dallas
    Had to Tig weld this little corner piece in on Monday didn't have anyone to hold it while i spotted it in place and couldn't get a clamp on it... Used the ole **** weld cleko trick ...thought I would show it... I use it all the time ImageUploadedByTJJ1366768102.615757.jpg
  18. zibo
    zibo
    from dago ca
    That's a good idea with the fish line.
    I did an f100 hood for a friend,
    and lost a couple of my clamp rods in that stash space inbetween the reinforcement!
    Hope he doesn't mind the rattling!
    TP
  19. Finnrodder
    Finnrodder
    from Finland
    I drilled holes too on the rods when i was fixing the p***engers side quarterpanels of my shoebox.It was so tight fit between the wheelwell and the quarter panel that pulling the rods out with wire was only way to remove them.I've seen these clamps for sale cheap too on ebay.24 clamps for 50 bucks is a bit cheaper than 4 for 20$..
  20. SlamIam
    SlamIam
    Thanks for that tip. I use the HF clamps a lot, they are available here. The gap is just right for my mig. If possible I weld from the back so there is little cleanup required on the outside of the panel.
  21. triumph 1
    triumph 1
    good info, i will be making some of these.
