Free case of oil? Yup.... Valvoline
Discussion in 'The Hokey Ass Message Board' started by tjm73, May 11, 2011.
  1. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I have heard this too, but have no experiance with it..dam i would hate to make the wrong move and pay dearly for it.:mad:..
    I have been very satisfied with Rotella..and its very easy for me to get my hands on , because i run it in all my companies trucks and Semi's
    I also get a killer deal on it because I buy it in the gallons..in gallon cans, and 5 gallon buckets, used to get it in a 55gallon drum..still might have one 55 gal drum still around here
  2. aerocolor
    aerocolor
    from dayton
    Uhhh, maybe I`m dumb or missing something but I just called my buddy at the parts store and synthetic is over $8 @qt case price so the rebate says up to $50.
    So you don`t get a free case just 1/2 priced after rebate.
    Is anyone else getting that situation out of this deal?
  3. patman
    patman
    Agreed...it is overstated. The fine print says '6 quarts, or a case', so...even at $8/ea, you could still get 6 quarts at least.
    Amazon has it for $61/case http://www.amazon.com/gp/product/B0...&pf_rd_t=101&pf_rd_p=470938631&pf_rd_i=507846 so you could do that and end up only paying $11. Think that's the right stuff...doesn't explicitly say synthetic though.
  4. MeanGene427
    MeanGene427
    from Napa
    The trick is to read and research, not listen to old wive's tales and witchcraft/voodoo logic. This is an "off-road" syn with proper levels of ZDDP for flat-tappet cams, not subject to the low-ZDDP regs for late models with cat converters
    For "the rest of the story", read here- which, BTW, was right there under "LEARN MORE" on the rebate offer page. So now you have a choice of two good ones from Valvoline that are safe for early engines with flat-tappets, a dino and a syn
    http://www.valvoline.com/products/consumer-products/motor-oil/racing-motor-oil/8
  5. Bleach
    Bleach
    So it sounds like I shouldn't use this oil in my wife's Honda.:p
  6. Von Rigg Fink
    Von Rigg Fink
    from Garage
    thats ok,, I dont take to change too well...you know, old and set in my ways..Been using rotella for so many years with absoluty no problems..I have no reason to change, im old and hard headded that way..so thats probably why i didnt bother to learn, or read further, Thanks Though
    although i may not p*** up a deal like this for other engines i have
    I like old wifes tails ..im an old husband:eek:...you say that like its a bad thing
  7. KJSR
    KJSR
    from Utah
    Thanks for the link. That's oil I can afford!
  8. 36DodgeRam
    36DodgeRam
    Thanks for the link! Best deal of the day.
  9. Abomination
    Abomination
    The poop:
    Valvoline® Racing Synthetic (VR1) Motor Oil
    The advanced racing synthetic trusted by top engine builders and crew chiefs to protect in extreme racing conditions.
    • Engineered to deliver maximum horsepower
    • High zinc/phosphorus for extreme anti-wear, including flat tappets
    • Track-proven to maintain pressure and protect from foaming
    • Compatible with gasoline or alcohol fuels
    • Available at participating auto parts stores
    Overview
    More NASCAR Sprint Cup and top NHRA crew chiefs use Valvoline. Valvoline's advanced racing synthetic is easily distinguished by its sapphire blue color, but the real difference is the track-proven additive package engineered to maximize horsepower and provide extreme wear protection. The high zinc SL formula is designed for the track, but is great for high performance p***enger vehicles too, including flat tappet applications. Look for Valvoline Racing Synthetic at participating auto parts stores.
    Sizes and Grades
    Name 20W-50 Engine Oil
    Size Quart
    Part 679082.0
    UPC 0-74130-01461-9
    Name 10W-30 Engine Oil
    Size Quart
    Part 679083.0
    UPC 0-74130-01462-6
  10. GJC
    GJC
    from Santee CA
    This is what I did.Thanks for posting this!
  11. thepolecat
    thepolecat
    This stuff should work fine in my 87 Silverado since it will not need a catalytic converter come January.
    Seems right in my logic. What do you guys think?
    If nothing else it will be good to have around for other projects and activities.
  12. cowboy1
    cowboy1
    from Austin TX
  13. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I got two cases at NAPA (I have 2 addresses) and they were confused as well. They have VR1 oil, but it's not synthetic. Nobody else around here carries it either. **** it then, I'll return mine, get my money back and have nothing :mad:
  14. KJSR
    KJSR
    from Utah
    I got mine from O'Reilly this weekend as well as some VR1 conventional that was on sale.
  15. TomT
    TomT
    Thanks - I'll give this a shot!
  16. Done deal.
    6 qts of 20/50 & a can of STP will work fine in my Blown & Injected Fuel Motor,,,on a stand.
