front leaf spring lowering
Discussion in 'The Hokey Ass Message Board' started by ronk16, May 13, 2011.
  1. ronk16
    ronk16
    Ok fellas which leafs do I remove in the stack to achieve my drop without rendering the springs useless, looking for 3 to4 inches.....59 f1oo
  2. derpr
    derpr
    every other one, but 3-4 sounds like alot
  3. jmdc
    jmdc
    Is this (every other one) a rule for any leaf spring drop?
    -Justin
  4. el Scotto
    el Scotto
    from Tracy, CA
    Reversing the eyes is worth an inch an' a half or two inchs. Did it last night in the garage on a Model A front spring.
  5. Rich Wright
    Rich Wright
    I've done this to a lot of Chevy ADs but never a Ford. With that in mind....I've found out th hard way that any more than two leaves results in a harsh ride. I take the first and third, which gives me about 3".
    If you can gather up the money I'd highly recommend a 3" dropped axle from Sid's...that in conjunction with one or two leaves will put you in the dirt:)
  6. I took out every second leaf on my 64 F-100. Came down 3". At first I had about 3/4" before it hit the bump stop, but now it's settled and rides right on the bump stops.
    It actually still rides half *** decent though.
  7. pasadenahotrod
    pasadenahotrod
    from Texas
    Rule of thumb I was told decades ago was remove 3-5-7-9-11, odd numbered leaves, always keep number 2, whether front or rear spring.
  8. ronk16
    ronk16
    sweet ......thanx fellas, gonna try the odd leafs,,,,7 spring stack, bye bye to 3 and 5.
