How low have you gone on your 63-66 C-10?
Discussion in 'The Hokey Ass Message Board' started by Butcher's Shop Customs, Feb 14, 2011.
  1. Butcher's Shop Customs
    from Paducah KY
    I'm staying with coil springs, planning on just cutting them down. I may entertain drop spindles if they make them for drum brakes.
    How low have you gone?
    This is for my 61 Suburban, running a 66 C10 front suspension. Right now the front end is sitting stock, the rear end is about 13" from the ground to the back bumper with 235/75/15 tires.
    Any info would help, pics would be great!
    Thanks again,
    Evan
  2. Butcher's Shop Customs
    from Paducah KY
    Bump? 39 views and nobody has lowered their C-10? :confused:
  3. 76cam
    76cam
    My 65 is lowered 2 in inthe front and 2 and a half in the back. I just cut on ring out of the spring and put blocks in the back. Rides fine with no problems.
  4. Butcher's Shop Customs
    from Paducah KY
    Thanks. That's what I was wanting to get a feel of, how much drop you actually get from a certain cut. I'll probably start with one ring, as I don't know how much drop I really have in the rear, since I was dealing with a leaf sprung 4x4, lift blocks, add a leaves, and all.
  5. roofer
    roofer
    from uk
    I have a 63 long fleet, big window, I am just in the middle of a full strip down and lowering project,
    1.5" front crossmember section, rear small step notch etc,
  6. roofer
    roofer
    from uk
    I have a 63 long fleet, just had the front crossmember sectioned 1.5" and going on air all round,
  7. customcory
    customcory
    I know cutting 2 coils is too much on these trucks on the front.
  8. AllenK
    AllenK
    3 inch lowering springs up front,and 6 inch in the back. I agree that 2 cutting 2 coils would look cool,but be too low!!!
