Lakewood Traction Bar Modification Welding Question
Discussion in 'The Hokey Ass Message Board' started by Moonlight Engineering, May 15, 2011.
  1. Moonlight Engineering
    from Eureka, CA
    Since my 1971 C-10 truck is lowered ( C-Notched and Spring Flip at rear ), the Lakewood traction bars made for this series truck does not fit without the bars hitting the pavement.
    I can cut and weld the mounting sections of the bars to make them function as designed ( see photo ).
    I don't think WHERE I want to cut and re-weld the bars will present any structural problem as far as the bars holding up with the stresses it will endure in use...but I thought I'd run this idea by the welders here at the HAMB before I went ahead and did it.
  2. shawnspeed
    shawnspeed
    from Attica Mi
    I would cut the bar loose from the attachment ,shorten & re-notch it like the factory just 2 1/2" shorter and weld back JUST LIKE THE ORIGINAL...Shawn
  3. KrisKustomPaint
    KrisKustomPaint
    I would make a lap joint and weld on both sides.
  4. 1971BB427
    1971BB427
    from Oregon
    Ditto on the lap joint. Way stronger to overlap what you want shortened than to cut it out.
  5. blue 49
    blue 49
    from Iowa
    I built CalTrac style bars since I didn't have clearance for ******* bars.
  6. cut, slide bracket down, weld. should take less time than it did to ask the question.
  7. ronald_rocheleau
    ronald_rocheleau
    from dyer in
    with reasonable welding skills, dont sweat it, just cutn weld, and move on,,
  8. d.reese
    d.reese
    X2, it also lets you tack it up and confirm fit up prior to welding out!
  9. Moonlight Engineering
    from Eureka, CA
    Hey guys, thanks for the input !!!! The lap joint makes the most sense for me being that it would be easier to maintain the proper mounting angle with a lap joint vs trying to re-notch the entire bracket.
  10. gimpyshotrods
    gimpyshotrods
    Just make sure that they won't hit the ground if you get a flat tire. That would end badly.
  11. Moonlight Engineering
    from Eureka, CA
    That's for sure. The cuts in the bars would configure them to the original positioning of the Lakewood design for a non-lowered vehicle so clearance will be adequate in the event of a flat.
