CHEAP and Great Alternative Coil Springs '49 thru '59 Ford and Merc
Discussion in 'The Hokey Ass Message Board' started by Fairlane Dave, Apr 26, 2008.
  1. carnut341
    carnut341
    Been running the 90 Ford Areostar springs on my 53 Ford 4dr for over a year and they work great!!!! Lowered the car about 2inchs and rides great.
  2. Doctor Detroit
    Doctor Detroit
    I'm going to try these Aerostar Moog coils and Monroe shocks listed in the first post on my '51 Mercury while I have it apart. I'm also looking for a less expensive and great alternative for the leaf springs in the rear, which one company sells for $400. Anybody have a suggestion?
  3. Doctor Detroit
    Doctor Detroit
    On Ebay I just ran across a company in MI selling new Dayton 49-51 Merc stock rear leaf springs with bushings for $225 + $50 shipping. Name on ebay is springking0001, or McVeighs' Truck Springs, Inc. Mio, Michigan 48647, Phone: 1-989-826-3682, Email: mcveighstrucksprings@yahoo.com.
    Jamco sells stock height up to a 4" drop rear leafs springs for $399 + $30 shipping + $22 bushings
    EDIT: See reply #188 for updated leaf spring info
  4. olosipu
    olosipu
    For safety's sake, do I need a spring compressor when replacing the original front coil springs on my 1950 ford? I read the green bible which says nothing about a spring compressor, so can I ***ume that when I lower the lower A-arm with a jack, that the spring fully decompresses? Any significant chance of the spring jumping out under pressure?
  5. rafael
    rafael
    from Moody AFB
    nah you'll be fine... just put the car on jack stands and place the jack under it and slowly release the pressure.
  6. 4Door54
    4Door54
    from Nor*Cal
    The original springs were heated up so good in mine, that when the suspension drooped out, they just rattled around!
  7. olosipu
    olosipu
  8. Doctor Detroit
    Doctor Detroit
    I'm not trying to hijack the thread, I'm just sharing Leaf Spring info for the rear. I called a handful of spring manufacturers, most would only make stock height leaf springs. St. Louis Spring Company made a 4" drop set of Rear Leaf Springs for my '51 Mercury for a very reasonable price. Bushings not included. The best part about it is I called to order them five days ago, and they arrived today.
    St. Louis Spring Company, phone: 314-533-2132
    http://SaintLouisSpring.com
  9. 58_Ford
    58_Ford
    from Phoenix
    Anyone know where to find spring specs. Im trying to Raise the front of my 58 Ford custom 300 and trying to find a taller spring.
  10. Sigg
    Sigg
    So I read through the thread, I have a 49 merc (4 door), completely stock. If I want to lower the car 3 inches in the front I can use the Moog PN CC850 Coils, can you tell me what shocks I need to buy? For the back I have the leafsprings, someone said use BLOCKS, what size and where do I get them? Also what shocks do I need for the back? Will I need anything else. Sorry for all the ?s but I want to make sure I do it right the 1st time.
  11. solo_909
    solo_909
    So any update on how the new astro springs settled? Could you take a 3rd photo and measure it again? Thanks
    George
  12. Doctor Detroit
    Doctor Detroit
    Sigg,
    I believe you want Gabriel 82026 or Monroe 5751 for the front. Lowering blocks for the rear are available different places, but check Speedway Motors for a 3" block. Your leaf springs should be 2 inches wide. Rear shock mounting points should be measured after you install the lowering blocks and possibly buy a shock to fit the new dimension. There's a guy on ebay in Fort Wayne who could help you. Search for 49 Mercury shocks, you'll find him.
  13. Destralo Roach
    Destralo Roach
    Cant show ya due to no camra but my 53 customline has a 3 1/2" drop in the front with the astro springs, I am running a inline six for the motor.
  14. JeffB2
    JeffB2
    from Phoenix,AZ
    There is a spring shop located off the corner of 55th Ave & Maryland in Phoenix by the Drive-In movie,they are an Eaton dealer they should have a catalog that shows the diameter and spring heights so you can find an interchange.
  15. solo_909
    solo_909
    Just installed the aerostars a couple days ago with 4" blocks. I've been driing around without the front shocks and the front drives pretty nice so I can't wait to install the new shocks.
  16. Tiffany
    Tiffany
    from seabrook
  17. olosipu
    olosipu
    Yes they will, if you have a stock suspension and put in aerostar springs, all will be fine. Replace the shocks with the standard size and dont forget the top spring rubber rings.
  18. Cabbage
    Cabbage
    thanks for the pics guys, im planning to unflip my spindles and use the aero springs on my 51 merc
  19. ynottayblock
    ynottayblock
    Ive read this whole thread and this question was asked already but with no reply:
    Will aerostar coils work on a 59 t-bird?
    Does anybody have a catalougue to reference whether the thunderbird used different coils than other 59 fords?
  20. Lono
    Lono
    I just did my wagon as well...
    before and now after...
  21. luvzccr
    luvzccr
    im putting a 460 into my 58 and i just got the headers from crites restoration, and in the instructions it said that i need at least 6 inches of clearance, and i need stock v8 springs.... i really wanted my car lowered, but i was hoping to find out if the aerostar springs will be good enough to work with now that i have these headers?
    if not, can i just put a coil spacer in there and it'll give a little extra clearance?
  22. fordsbyjay
    fordsbyjay
    from Lafayette
    Do the headers really hang down low or something that you need all that clearance? In my 56 the aerostar springs only lowered it 2". It has only been a couple weeks so they might settle a bit more yet.
  23. babylincoln53
    babylincoln53
    from dana point
    i just put these on my 53 merc. with new shocks.. looks way better .and drives nicer too.......
  24. Cabbage
    Cabbage
    so you guys who have done this swap. what about the steering arms??? stock? heated n bent? or aftermarket dropped? What did you use?
  25. easyissy
    easyissy
    I did this on my '58 Ford Custom 300. Used the stock set-up and it works fine.
  26. babylincoln53
    babylincoln53
    from dana point
    same here.. stock arm..seems fine..
  27. fordsbyjay
    fordsbyjay
    from Lafayette
    In my 56 everything else is stock. Just changed the coils and shocks.
  28. sololobo
    sololobo
    Love that 57 Ford, beautiful. I have the springs for my 59 and will hopefully get em in this spring, kind of a pun there. I want to do ball joints and a few other front end goodies at the same time. ~sololobo~
  29. Doctor Detroit
    Doctor Detroit
    Just a heads up for 49-51 Mercury owners using the Aerostar coils and are considering additional drop using lowering blocks up front. My recommendation is do not use the lowering blocks with Aerostar coils. In the picture below I have a 1" lowering block installed, but the Aerostar springs are too short to seat properly when the suspension is unsprung. The springs don't stay in place. I removed the 1" lowering block and now the coil spring is snug when the suspension is unsprung.
  30. ynottayblock
    ynottayblock
    Since this thread got bumped I will ask again. Does anybody know if the aerostar springs work on a 59 t-bird? or if the 59 t-bird front springs are the same as any 59 full sized ford?
