Just wanted to try this for myself...VINEGAR BATH...***UPDATE May 27th***
Discussion in 'The Hokey Ass Message Board' started by 3wLarry, May 15, 2011.
  1. This rusty tag took 2-3 times in fresh bath of metal rescue. I did one the old fashion way too much dust and energy. The bath is the way to go. I made try the salad dressing next.;)
  2. Torkwrench
    Torkwrench
    This is something I've been planning to try for a while. Found a plastic 55 gallon drum to use. :cool::cool::cool: Only have 1 gallon of vinegar, though. :eek::eek::eek: :D:D:D
  3. its a classic
    its a classic
    from montana
    kinda sounds like a personal problem! haha......so this vinegar takes off rust and paint? or just rust? what would happen if you used solvent? dangit this is intriguing me, now i have to try it!
  4. The37Kid
    The37Kid
    Are you using apple or g**** vinegar? Isnt the mol***as bath a quicker way to derust stuff?
  5. 69fury
    69fury
    from Topeka
    If you can skim off enough of the crud that precipitates out to keep using it, i think you can get quite a bit of life from it.
    I've heard the iron residue will turn your skin orange for a good long while-judging by what it did to some concrete-I BELIEVE IT!
    How about any reports on how well it takes off residual paint or grease? Any experiences there?
    -rick
  6. chris' 38
    chris' 38
    just hope it doesn't come out as fresh as a summer breeze
  7. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
    Yes,
    what larry is doing will work just fine, But the Mol***as bath works faster
  8. fleetside66
    fleetside66
  9. 3wLarry
    3wLarry
    from Owasso, Ok
    from what I've seen, it only removes the rust...not the original paint...which is what I'm after.
    kidcampbell71 likes this.
  10. 3wLarry
    3wLarry
    from Owasso, Ok
    I'm using white vinegar which I believe is corn vinegar...your mileage may vary
  11. The paint will come off too, in my experience.
  12. customizer2024
    customizer2024
    from niles, mi.
    X 2. I've had good luck with the paint also.
  13. joel torres
    joel torres
    im subscribed i tried this with safest rust remover but left it out on a sunny day and it evaporated before i got any results :( so next time il do it in the garage
    i wonder if you had something in the liquid that vibrated and agitated the chemical would it break down the rust faster or maybe a small pond pump to circulate it ??
  14. Mol***es works slower, in my experiences. I'm still amazed at the clean metal, when I squirt the parts off with the hose.
  15. Zeke
    Zeke
    I have to agree
    12 days later in a mol***es bath:eek:
    I got a gal of vinegar to use on some other less rusty stuff though.
  16. hot rod rod
    hot rod rod
    Hey....Whata Look Like....Got any Beer left after watching ? I know sum guys got food stamps will kick in for sum more beer. Have fun Youse' guys.
  17. BLAINE 816
    BLAINE 816
    We have been using white vinegar to clean the inside of rusty motorcycle tanks
    for years. It works great but takes time.
  18. LOWCAB
    LOWCAB
    from Houston
    Looks like you should put something else in that tank of yours to up the volume so that the wheel gets covered all the way. Sort of equivalent to putting a brick in your toilet to save water. Something non reactive with the vinegar of course.
  19. GaryB
    GaryB
    from Reno,nv
    got those pics of the g***er?
  20. Yeah Larry,,,turn on the Vin-Cam,,,we're bored.
  21. nali
    nali
    Suscribed . I m also a no life ..
    I d cover it better , vinegar evaporate .
  22. Phucker
    Phucker
    from Kansas
    I have de-rusted a whoooole bunch of stuff using white vinegar, I'd bet that wheel would have been almost clean in 24 hours, I've had most rust off within 36 hours of real bad parts.
    If you can go to Harbor Freight, they have little stainless steel brushes about the size of a toothbush, with plastic handles for 99 cents, those work good for getting a lot of the rust off after a short time in the vinegar. I usually just scrub it right in the vinegar, and then let it soak for more.
    Bolts that were completely covered in rust will usually clean up in about 8-10 hours with fresh vinegar, and a stainless steel brush.
    Have reused the vinegar several times, but after a few good uses, you may notice it doesn't bubble up as fast/good, and then I'd usually replace it, after those parts.
  23. So, the vinegar removes rust and paint - what about chrome........?
    Anything you shouldn't put in vinegar - I've read that pot-metal in a mol***es bath for example is not a good idea.....?
  24. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
  25. bump for later read
  26. saints
    saints
    worked great for me on a pair of model a springs...Go Larry Go!!!!!
    by the way if the rims for sale Ill take it;)
  27. 3wLarry
    3wLarry
    from Owasso, Ok
    sorry,not for sale...I have 4 more wheels to go.
  28. 3wLarry
    3wLarry
    from Owasso, Ok
    yeah...I'm gonna hafta go get some more vinegar cause it is evaporating.
  29. atch
    atch
    i've had vinegar turn chrome black; and the black didn't come off.
  30. Bad Bob
    Bad Bob
    from O.C. Baby
    hahaha! 3wEinstein!!!!!
