Just wanted to try this for myself...VINEGAR BATH...***UPDATE May 27th***
Discussion in 'The Hokey Ass Message Board' started by 3wLarry, May 15, 2011.
  1. 3wLarry
    3wLarry
    from Owasso, Ok
    I added 3 more gallons because of evaporation and I'm gonna let it set for a few more days.
    Then I'm gonna take the wheel to the carwash and see if high pressure spray will knock most of it off...wire brushing is too much like work, and you guys know how I feel about work. :rolleyes:
    kidcampbell71 likes this.
  2. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    Boy, this thread has been "swerving like ervin" um,.. i like the vinegar reports, getting the same results out of a small project i've been doing. i really like the G***ER the sunroof,hitch and full heater point to a street-freek" type car. i love it just as it it is!! some kinda cool panel paint action. i guess it depends on the history of the car to restore it or not.
  3. Rebel 1
    Rebel 1
    Good info. Thanks for sharing.
  4. How do they *make* vinegar?
    Im writing the Science Channel so they can put it on How Its Made...also sending in pics of the wheels,,,vinegars most popular wide spread(traditional) use!
  5. plym_46
    plym_46
    from central NY
    Vinegar should be pretty cheap away from the grocery store.
    Check around your area for a wholesale of bulk style grocery store. vinegar should be much more than a buck 50 a gallon. Some wholesale places have it in 5 gal pails for less
    When yer done strain it and make your own MAYONAISE..............
    Also for a bit quicker result, you can get phosporic acid (used for etching and cleaning concrete) from builders supply houses. It is more expensive than vinegar but its a stronger solution so it works a bit faster.
    Vinegar is nothing more than acetic acid usually in a 5 % solution but if you look around at commercial suppliers it can be found in 10%, which makes it about as effective as phosphoric.
    Muriatic acid is also out ther but it needs to be used out doors and with bubber golves and such.
    for big items like wheel and heads and such electrolysis is probably the most effective method.
    http://www.stovebolt.com/techtips/rust/electrolytic_derusting.htm
  6. 38Chevy454
    38Chevy454
    ALL of the types of acid do the same thing, they react with the Fe3O4 (Iron Oxide), the Hydrogen+ ions in the acid (all acid is defined by excess H+ in solution) react with the Fe3O4, making water H2O and leaving Fe+ ions in solution. So as you use the solution to dissolve rust, the vinegar or whatever acid solution gets weaker as it does it's job. Excess OH- (Hydroxide) is what makes a solution a base, opposite of an acid.
    Phosphoric acid is nice as it leaves an iron phosphate coating on the surface which is good for paint adhesion.
    Muriatic acid, otherwise known as swimming pool acid, is dliuted nitric acid and is probably cheaper than vinegar, just dilute the muriatic before use to about 25% strength. Any acid processing obviously be careful and wear eye protection, weak acid solution can be washed off your skin.
    Good progress reports Larry, just give it time. It will work.
  7. Muttley
    Muttley
    Next time try oxalic acid AKA wood bleach, works great and wont harm the paint.
  8. solidaxle
    solidaxle
    from Upstate,NY
    HHAAAAAAAAHHAAAAAAA
    We should have layed down some bets,just to make it interesting
  9. Jalopy Jim
    Jalopy Jim
    The ****-Fugging-Ugly-G***er, or better yet a Hillbilly Sunliner.
  10. d.reese
    d.reese
    Yep, thats why I own my on pressure washer. Hell take that old g***er, brush on some paint stripper, wait 20 min hit it with the pressure washer and down to the old primer or metal fast. Even works on steering boxs, ******s rearend with oven off then grab that 2500 PSI Bad Boy!!Love my pressure washer!
  11. truckncoupe
    truckncoupe
    That wheel looks very familiar...who did you get that from?:mad:
  12. Deuce_Eddie
    Deuce_Eddie
    from Portugal
    I'm a big fan of the pressure washer too, but I've been using basic engine degreasing stuff, letting it work in for a while, then blast it real good. Works a treat on grubby engine blocks or gearboxes!
    The phosphoric acid was awesome (must look at a construction store, I used to get it at the DIY stores but hasn't been available for years now), reasonably quick and the iron phosphate on the surface was really useful for containing further rust from appearing overnight, and was a nice key for paint. Some of the parts I felt most proud of were prepped like this, works great especially on odd-shaped parts.
    I've also been wanting to try the caustic soda process, must make that experiment one day.
  13. 3wLarry
    3wLarry
    from Owasso, Ok
    you, goober :) I gave Ronnie a '32 wheel instead and he liked it.
  14. nali
    nali
    I suppose you mean Hydrochloric , not nitric .
  15. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Damn this thread might take years.I saw the update and only added 3 more gallons .Lol Ill be watching and waiting
  16. pinupwithgun
    pinupwithgun
    When i was a kid i would climb up on the counter and go in the cupboard get the vinigar and drink it right out of the bottle. My mother eventually locked it up. No wonder i have indigestion problems!:eek:
  17. rodl
    rodl
    Hey 3wLarry, be interesting to see how it turns out. You may be interested to check this out - rust removal with mol***es. Apparently light rust disappears completely & heavy rust gets converted back to metal!!!! There's a guy over here who has built a tank big enough to fit a whole car in. just google up mol***es rust removal, there's also vid's on the subject.
    good Luck
    RodL
    Twin Pipes & Pin Stripes
  18. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Hell, if it doesn't work, you have the start of a Boat Load of Pickles, just add Cu***bers.
    VR&C.
  19. nali
    nali
    I use mol***es . It take weeks , or monthes .... But it s safe .
    And always fun to have the parts de rusting in a tank the whole winter for quite no cost instead of stored on a shelve in the garage ..
  20. Adriatic Machine
    Adriatic Machine
    I used to clean stuff with phosphoric acid, cleaned up really good and quick, and left the surface phosphated, so with a good clean it was ready to paint. Awesome stuff![/QUOTE]
    Phosphoric acid is used to p***ivate steel, like alodine to aluminum. It burns the surface and seals the metal from rusting again... like using high heat to sear a nice steak. FYI
  21. nali
    nali
    phosphoric is the best choice . Mol***es does the same thing . Too bad we can t find Ospho in Canada , s ..
  22. zmandet
    zmandet
    Wally World usually has a good supply of distilled vinegar, 2:16 gallon.......you should have seen how they looked at me and the wife when we had two carts filled with 20 gallons....LOL. By the way my experiment was on a 35 gallon fuel tank for a M-F 60 Tractor......cleaned it up well.
  23. Warm it up (a fish tank heater works a treat as per an experiment a mate of mine did). It will fasten up the process considerably.
  24. 1971BB427
    1971BB427
    from Oregon
    Man that vinegar seems to really work!
    Love the Ford g***er too! The scoop and sunroof are easy fixes, and funny thing is I had to remove the same scoop and sunroof from my car! Took awhile to get the roof opening patch panel welded in, but you can't tell it was ever there now!
  25. tommy
    tommy
    Whew!! now mabe I can get some sleep tonight.:D I've been tossin' and turnin' all night waiting for this.
    I like your new project for obvious reasons. I'm hoping to get mine running this week. Fire in the hole always stirs the juices. I'm making this one into a Mainline with no options. A stealth street racer and not a real g***er.
  26. Bart78
    Bart78
    I have used the stuff to take blueing off guns when fixing them.
  27. shmoozo
    shmoozo
    from Media, PA
    Um ... The last time I had the misfortune to catch a glimpse of a cat's *** I was reminded of just how unattractive looking they are.
    Well, to me, anyway.
  28. harrington
    harrington
    from Indiana
    That vinegar bath must be awesome, even fixed the dents and moved the spark plug wire looms around. Good Stuff!:D
  29. Larry W
    Larry W
    from kansas
    Main thing is to NOT let the fumes get to you . Makes you see things that are not there.
  30. daddio211
    daddio211
    That's what I was thinking too, LOL.
