Carpet question!!!!
Discussion in 'The Hokey Ass Message Board' started by S2X01, May 18, 2011.
  1. S2X01
    S2X01
    anyone think that with minor modifications....a carpet set from a GM B body car would fit in a GM E body car?
    Same years.....found a carpen set from a 67 Impala. Wanna put it into a 67 Riviera.
    Thoughts?
  2. Julio
    Julio
    from san diego
    yea, use a blowdryer or heat gun and that helps make it easier to work with, and leave enough slack under kick plates and stuff, should fit..
  3. stanlow69
    stanlow69
    Call Auto Custom Carpets in Alabama, they should be able to tell you if they are interchangable. Should fit dosen`t mean it will.
  4. S2X01
    S2X01
    I'll make a few phone calls. After looking at pictures....they do look close. Plus I'm trading a few things for it potentially. Things I don't use.... so might be worth it even if I have to modify a bit.
    Thanks Guys!!!
