Just wanted to try this for myself...VINEGAR BATH...***UPDATE May 27th***
Discussion in 'The Hokey Ass Message Board' started by 3wLarry, May 15, 2011.
  1. RichG
    RichG
    When you're done with your vinegar you can bottle it and sell it to the Old Skoolerz as "Eau de Patina".
    ...and who knew there were so many chemists on the Hamb?
  2. andyg
    andyg
    Might be a good idea to neutralize the acid with ammonia when your finished. That stops the acidic reaction. Water does not stop the reaction. It dilutes it but does not stop it. If you don't nuetralize it with a base solution such as ammonia then the acid will still be eating on it five or ten years from now!
  3. busguy71
    busguy71
    electrolysis would have been cheaper, throw a battery charger on a piece of steel, add water, and spend $3 on laundry soda, cleans parts in minutes to hours, not days.
  4. The dog's ******** then? :D
  5. yblock292
    yblock292
    Hell larry should be , everything else is!
  6. Tom S. in Tn.
    Tom S. in Tn.
    How about the Tom cats's ***s ? I get that one a lot.
  7. daddio211
    daddio211
    So this beg's the question (no, not cat's ***, dog's balls, or tom cat's ***s):
    Has anyone tried electrolysis in vinegar? No, I didn't do a search for it first! :)
  8. breeder
    breeder
  9. tinmann
    tinmann
    8 pages in..... and I can't believe I'm the only one to say it....... Larry, you're a ****ty scientist. Don't you know that in order for this to be scientific you have to have another wheel soaking in a placebo vinegar? If you don't, then the wheel that is currently soaking may very well have derusted itself due to the power of self-healing..... not vinegar. C'mon, get scientific or give up the charade.
    Nice g***er...... what's the plan?
  10. MeanGene427
    MeanGene427
    from Napa
    Just picked up 12 gal of vinegar from the owner of the local greasy s****- but now I gotta go out with his waitress again, been gettin' a little ornery lately, needs a little therapy- damn, what a guy'll do for his car stuff :eek:
    If 12 gal ain't enough, maybe I'll go to Costco :rolleyes:
  11. 38Chevy454
    38Chevy454
    You're right, should be hydrochloric. Memory playing games with me..... :rolleyes:
  12. nali
    nali
    Yes ... I know .... The problem is last time I did it , my tropical fishes all died , an then my kids cryed a lot .... Not to mention I had no "intimate moments " with my girl for about 3 weeks ....
  13. TXMark
    TXMark
    reverse electrolisys works better with nothing removed but the oxidized metal
  14. evintho
    evintho
    I've used vinegar on tools and it works great. For larger, seriously rusted car parts I use mol***es. Built this 4' square tank in my backyard and lined it with a pond liner. You can fit most anything in there. 20 gallons of mol***es costs $60. Diluted it 7:1 with water. Broke down my roadster body and let the panels sit in the brew for 2 weeks. Came out clean as a whistle!
    Also threw in these '35 wires and a bunch of early suspension parts that were basically a block of rust. They came out like this. Mol***es doesn't touch original paint, chrome, rubber or pot metal!
    Just thought I'd add something extra to this vinegar thread.
  15. nali
    nali
    Vinegar and moll***es don t do the same way ....
    Vinegar is acid , and will eat anything . Even a AMC Gremlin after Midnight . Use any acid .... Hydrochloric , Muriatic ( the same ) , formic , acetic , glogloric , the necro-ulric ...... all will destroy metal .
    The other way is chelation , as done with mol***es . Or phosphoric acid . Probably the best way .
    There s been thousand of topic about this ..... Electrolysis works also . It s also safe for no heated metal as a spring .
  16. Harry Bergeron
    Harry Bergeron
    from SoCal
    After a vinegar bath, steel parts want to rust very quickly.
    Wipe them down to get the black crud off, and wire brush to finish.
    Either primer right away or rub oil into the metal.
    I use motorcycle chain wax, doesn't attract dirt.
    I reckon mol***es is better all things considered.
  17. nali
    nali
    Epoxy primer ....
  18. mrspeedyt
    mrspeedyt
    this is more exciting than watching paint dry!:rolleyes:
  19. Rick Sis
    Rick Sis
    from Tulsa OK
    There has been an odor lingering in the air all the way over at my house that smells like someone has been dying Easter eggs.........guess I found the culprit.
    I did my own vinegar experiment last winter. Just some small parts in a mason jar. It is truly amazing. It's not fast, but does a great job.
  20. nali
    nali
    Same smell , and off topic , but silicon cures really fast when you mix it with a few drops of water . Usefull to make a cheap and fast pattern .
  21. handmedown40limited
    handmedown40limited
    from tracy ca
    Well after reading your craigslist post. Looks like u will need a really big tub and a lot more vinegar.congrats
  22. Big T
    Big T
    from Florida
    I figured that out when my girlfriend entered a wet t-shirt contest. Sorry, I thought ya meant silicone. :D
  23. What happened? Where are the results? Enquiring minds want to know.
  24. patman
    patman
  25. oldpl8s
    oldpl8s
    I've been looking but can't find mol***es in large quan***ies. Where did you get it? thanks
  26. big creep
    big creep
    equestrian supplies, arcadia, burbank, sunland look it up. they sale it by the gallon.
  27. belair
    belair
    tractor Supply.
  28. 02lowrider
    02lowrider
    from Round Rock
    This is interesting and helpful....I've got plenty of rusted parts so off I go to the store!
  29. 3wLarry
    3wLarry
    from Owasso, Ok
    Forgot all about this stupid thing...12 days in the vinegar...pulled it out and simply hosed it off...no scrubbing. The brown color is primer, not rust.
    Damn! Am I REALLY that fat?!...****
    kidcampbell71 likes this.
  30. big creep
    big creep
