COE COE Picture thread (imported from main board)
Discussion in 'Off Topic Hot Rods & Customs' started by Duration, Oct 30, 2007.
  1. LN7 NUT
    LN7 NUT
    I've always wanted a 51-53 Dodge COE like that!
    BTW, it's site rules to make your first post an introductory one, better get on that before people get upset.
  2. Here's another pic of the insides. Since I am not sure of my body work skills it makes me nervous.. Does $600 sound like a decent price. All the chrome and trim seems intact and there
    Uploaded with ImageShack.us
    Thanks you guys, (and gals)
  3. LN7 NUT
    LN7 NUT
    Sounds good to me, I'd pay that for it, and I have body shop skills!
    I would like to see the floor in it, so far the interiro is the same as a pick-up, but how bad is the floor hump?
    When I was looking for a COE I checked out a few including a 46 Ford and a 56 Chevrolet snub nose, and they had such a small amount of floor space, and I am over 6 feet tall, so i just could not get comfortable in them, so I got a 1956 Mercury COE. (the floor hum/dog house is all of 6 inches wide and 4 inches deep)
  4. Thanx Ln7NUT. The floor hump is 3-4" high from what I can recall and I didn't notice how wide it was. When I sat in it I had a lot of leg room and even though I am only 5'9" I have a 34" inseam so I need a lot of room for my legs. That seemed ok even with the old bench seat it has in it. The floor has about 6 inches of old seat and roof liner laying on it and I was more focused on looking for rot holes than paying attention to the hump. I should have paid closer attention to that detail. Here's the pic that shows the floor a little better. Thanx for your input on this. Much appreciated
  5. mart3406
    mart3406
    from Canada
    It depends on what the registered GVW
    of the truck is - and whether or not it has
    air-brakes or is hauling Haz Mat. So long
    as the GVW is under 26,000 lbs and the
    truck doesn't have air-brakes - and you're
    not hauling hazardous materials in
    quan***ies high enough to legally require
    placarding, you don't need a CDL.
    Mart3406
    (Excerpted from:
    www.testquestionsandanswers.com/cdl/texas.html )
    To operate a commercial vehicle in one
    of the following cl***ifications, you must
    have a Texas CDL Endor*****t.
    CL*** A - This cl***ification applies
    only to "combination" vehicles with a
    Gross Combination Weight Rating
    (GCWR) exceeding 26,000 pounds,
    provided the Gross Vehicle Weight
    Rating (GVWR) of the vehicle being
    towed exceeds 10,000 pounds.
    CL*** B - This cl*** includes single
    or combination vehicles where the
    GVWR of the single vehicle exceeds
    26,000 pounds. The vehicle in tow
    must not exceed 10,000 pounds.
    CL*** C - Vehicles designed to transport
    16 or more p***engers, including the
    driver, and vehicles placarded for
    hazardous materials, that do not meet
    the criteria for Cl*** A or B above fall
    under this cl***ification.
    About the CDL Knowledge Tests
    You will have to take one or more
    knowledge tests, depending on what
    cl*** of license and what endor*****ts
    you need. All CDL applicants must take
    the general knowledge test. The table
    below will tell you what additional tests
    you must take, if any.
    Take If...
    P***enger Transport ...you want to
    drive a bus
    Air Brakes ...your vehicle has
    air brakes
    Combination Vehicles ...you want
    to drive combination vehicles
    Hazardous Materials ...you want
    to haul hazardous material or waste
    in amounts which require placarding
    Tankers ...you want to haul liquids
    in bulk
    Doubles/Triples ...you want to pull
    double or triple trailers
    Skills Tests
    If you p*** the required knowledge
    test(s), you can take the CDL skills tests.
    There are three types of general skills
    that will be tested: pre-trip inspection,
    basic vehicle control, and on-road driving.
    You must take these tests in the type of
    vehicle for which you wish to be licensed.
    1. Pre-Trip Vehicle Inspection: You will
    be tested to see if you know whether
    your vehicle is safe to drive. You will be
    asked to do a pre-trip inspection of your
    vehicle and explain to the examiner
    what you would inspect and why.
    2. Basic Vehicle Control: You will be
    tested on your skill to control the vehicle.
    You will be asked to move your vehicle
    forward, backward, and turn it within a
    defined area. These areas may be
    marked with traffic lanes, cones, barriers,
    or something similar. The examiner will
    tell you how each control test is to be
    done.
    3. On-road Test: You will be tested on
    your skill to safely drive your vehicle
    in a variety of traffic situations. The
    situations may include left and right
    turns, intersections, railway crossings,
    curves, up and down grades, and single
    or multi-lane roads, streets, or highways.
    The examiner will tell you where to drive.
    What Are The Other Requirements For
    A CDL?
    Federal Motor Carrier Safety Regulations
    require drivers to p*** a physical
    examination once every 2 years. The main
    physical requirements include good hearing,
    20/40 vision with or without gl***es or
    corrective lenses, and a 70-degree field of
    vision in each eye. Drivers must not be
    colorblind.
    What Should I Bring To The Department
    Of Motor Vehicles?
    In addition to testing, all first time original
    applicants must visit a local Texas Driver
    License office and present and do the
    following:
    * Present proof of iden***y.
    * Present proof of social security
    number.
    * Present proof of Texas vehicle
    registration and liability insurance
    if you own a vehicle.
    * Consent to be photographed,
    fingerprinted, and provide your
    signature at the time of application.
    What Fees Will I Have To Pay?
    Fees are as follows:
    Original Commercial Driver
    License: $61
    CDL Examination: $11 per exam
    Where Can I Get More Information?
    To download the Texas CDL
    Manual:
    www.txdps.state.tx.us/internetforms/Forms/DL-7C.pdf
    For federal requirements for a CDL:
    www.fmcsa.dot.gov/registration-licensing/cdl/cdl.htm
    For medical requirements:
    www.fmcsa.dot.gov/rules-regulations/administration/medical.htm
    Texas Department of Public Safety:
    www.txdps.state.tx.us/DriverLicense/CommercialLicense.htm
    Texas Department of Transportation:
    http://www.dot.state.tx.us/
  6. vintage56
    vintage56
    $600 is very fair for that Dodge coe
    at the farm auction a couple weeks ago, the s****pers were paying $1000 for that right there.
    i'm still nauseated.
    JML
  7. mart3406
    mart3406
    from Canada
    The body doesn't look all that bad. I think it'd
    look great sitting on a '93 Dodge 1-ton diesel
    4X4 ch***is too!. In a follow-up post you
    mentioned that you could get it for $600.
    For that price, if you don't grab it, a s****per
    surely will and it'll be gone forever.:eek:
    Mart3406
  8. Old Roadster
    Old Roadster
    X2 Grab It..........I would.
  9. mart3406
    mart3406
    from Canada
    Nice old truck...but methinks 'yer springs
    are all plum wore out'!!! :eek::D:D
    Mart3406
  10. TGIF all! I appreciate everyone's advice on the 51 Dodge. and I did post an introduction on the newbie area. Sorry for the offense. I called the old timer that owns the old beast and told him I'd take it. Will run over there Monday and pay for it before someone else does. Is there a website on where to find the production totals for the Dodge versus Ford/Chev. I googled that and couldn't find anything that was helpful. Just curious how rare Dodge's are versus any other model. Thanx again for all your advice on this.
  11. bigdav160
    bigdav160
    I do not believe actual production figures are available. But in light trucks (1 ton and less). Chevy and Ford each built about 5:1 to Dodge. International truck production was similar to Dodge and Studebaker about 1/5 of that.
  12. mart3406
    mart3406
    from Canada
    Just a little tip about when you go to buy
    it on Monday. If he's asking 600 bucks for
    it, take that much with you, in the form
    of six 100-dollar bills. But only put four of
    them in your wallet and maybe put the
    other two in an envelope and leave it in the
    glovebox of your car. Try offering him 400
    dollars for it and show him the four bills you
    have in your wallet. You just might end up
    getting it for that. And if that doesn't work
    and he still insists on the full 600-dollar
    asking price, you're still ok. It's worth
    a try anyway! :)
    By the way too. Once you get it home and
    pull the cab and anything else you can use
    off it, you can probably sell the original
    flathead six out of it - maybe to somebody
    here on on the HAMB even, to recoup some
    of your money - and then some more still
    by selling the frame, rearend and other
    unusable parts for s****. With a bit of luck
    you could maybe just about break even on
    the cab.
    Good luck with everything.Hope you get it!
    Mart3406
  13. Baron
    Baron
    A little more (a lot more actually...) cutting and welding to enlarge the rear fenders. Just have to finish the leading edge,weld up a couple more seams and they will be ready to remove, knock out the dents, hammer and grind all the welds and off to the blaster.
  14. OahuEli
    OahuEli
    from Hawaii
    The proportions look real good. Your truck is going to turn out nice.
  15. Hi,
    It has been suggested that my first post, that had my name and location and what I am building wasn't enough introduction.
    so I will try again.
    I live in calgary , self emplyed auto/collectables restoration,custom paint, been in the industry 27 years. Got into old cars naturally,my father loved them and he had a '27 Chrysler,and a '52 Meteor. I presently have a '69 Chevy short fleet ,396,3 speed lever,and a '39 GMC COE that is slowly getting worked on. Plan is to build a pickup style truck. Although I have had some cars, and I really like cars,
    I've always been a truck guy.
  16. HOTFR8
    HOTFR8
    http://www.jalopyjournal.com/forum/forumdisplay.php?f=18 Can I point you to the Introduction section of the forum. :)
  17. mart3406
    mart3406
    from Canada
    Jeez....I've always wondered.....how
    the hell would we ever survive here,
    without the constant vigilance and the
    strict enforcement of the 'introduction
    police'??? Quick....a crime's been
    committed...call the cops!!!:eek::eek::D
    Mart3406
  18. Rods & Relics
    Rods & Relics
  19. RMR&C
    RMR&C
    from NW Montana
    x1000!!!!!
    Chevyshortfleet, welcome to the nuthouse! Post some pics of your COE, I'd love to see it.
  20. RMR&C
    RMR&C
    from NW Montana
    I've posted this one before, but I ended up buying this old '51 cab the other day. Would love to build a dually hauler.......but I have so many other projects, it may go back up for sale.:mad:
  21. OK, i've re reintroduced myself, can I play now? : )
    I will get some pics posted of my COE
  22. onemintcaddy
    onemintcaddy
    ****,,,,,,,,,,,, I think I forgot to introduce my self back in 07. Just stick one of your Ex's in your Avatar and no one will notice.:D
  23. PKap
    PKap
    from Alberta
    Hey Baron, love the amount of work in your rear fenders, most guys just throw the little pu ones on and totally screw up the look, looking forward to seeing it done
  24. CayoRV
    CayoRV
    Onemintcaddy, if thats one of your ex's, DAMN! I'll be glad to take your castoffs any day!
  25. phat rat
    phat rat
    Yea but notice he only shows the rear. What's the front like? Uhm I wonder?????? Flat, ugly as a fence post??? Or is it a guy in drag??? LOL Let your imagination take you to the worst rather than the better. Just kidding onemintcaddy
  26. Truckeez
    Truckeez
    Yea... Im not really very active on this forum---i mainly just come here to scann for your avitar.....
  27. Locomotive Breath
    Locomotive Breath
    from Texas
    Baron,
    The truck is looking good. The bed and fenders are turning out great.
  28. b-bop
    b-bop
    Found this while surfing the web on the weekend. Being built at SAR. Cant wait to see it done
    Electric 1939 COE
    What you are looking at here is a 1939 Ford COE (Cab Over Engine) that has been radically modified. Two COE’s and one 1938 Pick-up are being used to create a Crew Cab COE that is almost 4 feet longer and exactly 20” wider to fit on a Ford F-650 ch***is, powered by a 500hp/800ft-lbs Electric motor, with a custom two-speed transmission and 180kWh of Lithium-ion batteries. It’ll be able to fully recharge from empty in 30 minutes using DC quick-charge, or four hours using 220V AC. The cost of the electricity for a full charge will be about $21, less than an eighth what it would cost to fuel a diesel truck of similar size. This COE is the largest and most heavily-modified of a series of trucks we have performed the metal work on for a company called EcoTruc. All of the trucks are showpieces and prototypes for EcoTruc, which is building electric trucks for the utility and municipal fleet market. This truck will be used as a show vehicle, but also a functional on-the-road technology demonstrator. It will also serve as the tractor for EcoTruc’s vehicle-transporter trailer that will take the other trucks to shows and their 1934 Ford electric race car to Bonneville and El Mirage. The race car will be powered by the same motors as this truck, with radically different gearing, aiming to go three times as fast!
    Tons more pics can be found here
    http://www.realsteel.com/projects.php?projid=86&ptype=1
  29. Starbuck_88
    Starbuck_88
    I LOVE this thread! I am wondering has anyone ever attempted or looked into puting one of these on a newer step van ch***is? They are already forward control and it seems they might be easier to adapt. That said I haven't found the Cab I want yet so I have no idea the measurements of the 40's 50s coe's. Any idea where I could find those?
