1949 F1 Steering Wheel Removal.....
Discussion in 'The Hokey Ass Message Board' started by Dads_Last_Ride, May 17, 2011.
  1. Dads_Last_Ride
    Dads_Last_Ride
    Is there ANY way possible to dis***emble the steering box from the steering column other than removing the steering wheel?? I only ask because I don't have a puller for the wheel.....
    Thank you....
  2. tb33anda3rd
    tb33anda3rd
    no, maybe you can rent one. they are not that expensive, or for that matter hard to make.
  3. Dads_Last_Ride
    Dads_Last_Ride
    SO I was going to use a pully puller but there are no holes for the outside bolts. And the wheel is too dry to beat on it with a mallot... What kind of puller would you recomend?? Any links to one I could buy that someone KNOWS will work? lol Im desperate here!!!
  4. alchemy
    alchemy
    Are there a couple tapped holes in the center of the wheel, under the horn cap? If not, can you drill and tap some?
    Than make a simple flat bar puller with a large pushing bolt in the center, and two clamping bolts in the ends.
  5. thunderbirdesq
    thunderbirdesq
    There should be two tapped holes under the horn ****on on either side of the main nut. I've never seen an F1 wheel without them.
  6. Dads_Last_Ride
    Dads_Last_Ride
    No tapped holes... Damn.
  7. Dads_Last_Ride
    Dads_Last_Ride
    It looks like so.... lol
      357.2 KB
      490.7 KB
  8. pineapple power
    pineapple power
    any updates on getting the steering wheel off? im in the same predicament.
  9. tb33anda3rd
    tb33anda3rd
    you have to drill and tap two holes, and use a puller.
  10. RMR&C
    RMR&C
    from NW Montana
    Whichever puller you use, leave the nut on the shaft......just back it off to the end of the threads. The shaft is hollow, and will mushroom/ split really easy. Ask me how I know.....
  11. Bronk1
    Bronk1
    from Norman, OK
    and so i goofed and mushroomed the end. the whell never budged. what to do now
  12. Doc’s 49
    Doc’s 49
    Yep…it sure will…I just found out.
