old style aluminum buckle canvas seat belts
Discussion in 'The Hokey Ass Message Board' started by john walker, Nov 13, 2010.
  1. john walker
    john walker
    i need some for my diamond t. kind of aircraft looking, with a big square aluminum buckle and tan colored canvas-like webbing. the chrome buckle/nylon webbing ones just don't do it for me. i had a set in a 55 buick wagon that i stupidly let go with the car. does anyone have a source?
  2. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    early rotunda ford belts have the aluminum clamshell type buckle. can sometimes be found cheap online.
  3. john walker
    john walker
    thanks, i'll keep checking for those. rotunda is the brand name i ***ume. any other ideas?
  4. Do a search in the cl***ifieds.
  5. junk yard kid
    junk yard kid
    someone makes them new but i cant remember who
  6. terryr
    terryr
    from earth
  7. john walker
    john walker
    i may have to go that way. pretty close, but the duller aluminum buckles have an older look.
  8. john walker
    john walker
    an older post, but still looking for a set of belts with an aluminum aircraft style buckle and canvas webbing. any leads?
  9. pcterm2
    pcterm2
    what about a aircraft boneyard?
  10. iammarvin
    iammarvin
    from Tulare, Ca
    While in the "libairy" this morning, Juliano's as some old style wanna be's.
  11. gtkane
    gtkane
    I know it a dreaded "import", but I had a 71 Datsun 510 that had those style lap belts. Might wanna try the wrecking yard.
  12. I found these that were missing the original webbing.
    Aircraft.
  13. Boeing Surplus Sales
    20651 84th, Seattle, WA 98101 &#8226; <!-- debug: bizProfile.isPhoneHidden - false ; bizProfile.isPaid - false -->(425) 393-4065
  14. john walker
    john walker
    unfortunately, boeing surplus closed up a while back.
    the julianos belts are kind of what i want, square buckle and all, but i'm holding out for square aluminum buckles and natural canvas color belts. searching "aircraft seat belts" on ebay may eventually turn some up.
  15. gwhite
    gwhite
    SUPER MODERATOR
    Be careful with belts advertised as "WWII", most are not. Best way to tell a WWII belt from a postwar model is to look for cotton webbing (used until at 1955 or so). Nylon belts are modern.
  16. Special Ed
    Special Ed
    I'll try and dig through my stuff, and see if I have a matching pair for you. I know I have exactly what you're asking for, just not certain if I have a pair. The Muntz Jet was either the first, or one of the first to actually put belts in their cars (as a marketing gimmick, not for safety), so mine would be from the very early fifties.
  17. BuiltFerComfort
    BuiltFerComfort
    Seat belt webbing made before 1955 probably doesn't have the original breaking strength. Meaning in a wreck they might break and hurt you. So see if you can find modern webbing to go in those old belts.
  18. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    What about using the Juliano's belts and then scuff the finish to look older? That way your webbing isn't old and rotten. Might look right and be safe as well?
  19. stuart in mn
    stuart in mn
    Snake Oyl also sells new seat belts with the old style buckles. They are polished chrome as standard, but they can also provide them with a brushed chrome finish. http://www.ssnake-oyl.com/ I just did a little searching and found this source: http://www.andoauto.com/SBL1-1N.htm, they also have a satin finish buckle available.
