The Inline Modified version 2.0
Discussion in 'The Hokey Ass Message Board' started by Empire32, Feb 5, 2009.
  1. James D
    James D
    Superb work. Unique car.
  2. Mart
    Mart
    Looks great, Etienne.
    Mart.
  3. nali
    nali
    What is the oil pressure gauge from ?
    Nice place and I love it .
  4. jerseyboy
    jerseyboy
    Looks great! Love the pressure gauge location.
  5. 64 DODGE 440
    64 DODGE 440
    from so cal
    The black and white picture is perfect...1950's garage shot...you should sell that as a poster!:D
  6. Empire32
    Empire32
    from FRANCE
    thanks ! I don't know from where the oil pressure gauge come, but it's a vintage Stewart Warner unit. I wished to put it a little bit higher, but there is a square tube structure just behind the firwall at this place.
  7. uglydog56
    uglydog56
    Your car is so amazing it almost makes me want to put mayonnaise on my pommes frites! Almost. Great work!
  8. Empire32
    Empire32
    from FRANCE
  9. 41 Dave
    41 Dave
    Etienne,Hope you are having a great year. Will you be posting any updates in the near future ? You sure have us hooked on the progress of this build.
    Dave
  10. Empire32
    Empire32
    from FRANCE
    for sure ! But I don't have enough time to work on it those times. Hope to work on it in july. And don't worry, I will post updates !
  11. 41 Dave
    41 Dave
    Etienne, Will be looking forward to your update in July.
    Dave
  12. Empire32
    Empire32
    from FRANCE
    Some progress, but without detailled pics: I've started to work on the wiring, front and rear lights is already done, Next step; fuse panel/dash...
  13. 41 Dave
    41 Dave
    Ettiene, Car is looking great. Looking forward to you getting it running.
    Dave
  14. Motornoggin1
    Motornoggin1
  15. Pauly da mick
    Pauly da mick
  16. Empire32
    Empire32
    from FRANCE
    Some progress: New airfilters, using cheap chinish speedway air filters, by swapping the cheap chromed and louvered caps with some old french Citroen van's center wheel caps.
    Still working on the wiring, using modern cable wrapped in old looking asphalt wire looms. Front & rear lights/turn signals are done, next step, fuse panel and dash wiring. I've started also to work on the dash, dash insert and instrumentation, switches, etc..
    Front licence plate is now bolted ( with a Hamb topper), using a clamp system, so, no holes in the I beam.
  17. striper
    striper
    Love those air cleaners.
  18. Empire32
    Empire32
    from FRANCE
    the famous Citroen Van: (I've also used the aluminium running board protections as a under pedals "floor mat")
  19. Empire32
    Empire32
    from FRANCE
    some progress
    homemade Fuse panel
    I try my best to ad some fake patina on the cheap taiwan made turn signal switch...
    general view of the dash
    adapted a licence plate light on the 50's Renault plate, also modified in order to bolt the great topper made by Whizzerick some years ago
  20. nali
    nali
    Nice use of the HY parts .
  21. 41 Dave
    41 Dave
    Etienne, Like all the trick little add on parts. It sure adds to your rod.
    Dave
  22. Empire32
    Empire32
    from FRANCE
    some progress !
    First, on the exhaust sytem. The langdon split exhaust manifold is cool, but one of the outlet is just right on the steering box ! So, I decided to don't use a double line, and worked on this junction, in order to turn around the steering box, and run under the car. Here we go, with a 2 parts piece (easier to install).
    and on the car, with a Smithy's muffler and a straight tube. Not sure if I will use the muffler, or just have a long tube and an intern baffle, will think about it. If I use the muffler, I just need to change a little bit the angle, to have the exhaust more in the car's axle...
    and worked on some details, not always visible. I changed the hex bolts on the firewal to slotted ones, more "period". finished also the fuel line.
  23. Twisted6
    Twisted6
    Looking Good :) keep that up and one day you'll be driving it right :)
  24. 41 Dave
    41 Dave
    Etienne, Car is sure finishing off real nice. Need to do a video so we can hear this built up six banger !
    Dave
  25. Motornoggin1
    Motornoggin1
    Turning out very nice. Very inspirational!
  26. Empire32
    Empire32
    from FRANCE
  27. Empire32
    Empire32
    from FRANCE
    Exhaust is now done, including hangers.
  28. Empire32
    Empire32
    from FRANCE
    some progress
    I made some brackets for the turn signals, made from 30's Renault fender lights (Front light are Citroen Traction).
    Worked also on the door hinges. I don't have the original ones, and they are pretty rare. to be continued
    I've chopped and streched a Citroen C4 windshield frame. I need now to create some winshield posts. But I don't realy like the car with a windshield, it's look really better without it. But the entire system will be easy to take off, so I will have several options (like also a english Brookland aeroscreen).
  29. Have a look at the windscreen posts on Caterhams - just cut from flat ally plate;
  30. Empire32
    Empire32
    from FRANCE
    some progress !
    Home made door hinges done !
    Then, I worked on a Hallock style windshield "sktech" to find a better way to have a windshield, because I wasn't happy with the classic windshield. So, it's just a rough test (here with photoshoped glasses), I need now to find the better line, height, and then make it larger, and have it aluminium cast...If you have some ideas or advices, Go ahead !
