Looking for Flathead standard oil filter
Discussion in 'The Hokey Ass Message Board' started by Shady1, May 29, 2011.
  1. Shady1
    Shady1
    from Australia
    Hi guys
    I have read all the oil filter stuff about flatheads. Full flow mods , running with no filter etc.
    But all I want to do is run the standard head mounted canister on the head with the standard 10% by p*** filter.
    Does any one know where I can buy a new filter cartridge ????
  2. fenderless
    fenderless
    from Norway
    I think Fram has one that fit!?
    Last time i bought one, i ended up with another brand(Canadian), that had a paper insert that fit. Sorry don't recall the name.
    Taildragger&fenderless
  3. tbill
    tbill
    from central ny
    local napa should be able to get them for you, or carquest if you have one near you.
  4. Wix has them, that's what I use on mine.
  5. thunderbirdesq
    thunderbirdesq
    Napa.
    Hi Scott:), fire that fresh flatty yet?
  6. 29ron
    29ron
    Sacramento vintage ford
  7. FRAM - Part # C4 (pleated paper) and #C4P (stacked media)
  8. Shady1
    Shady1
    from Australia
    Thanks guys, I should be able to find one now
  9. Shady1
    Shady1
    from Australia
    No luck guys. The Fram #C4 is the same type of cartridge as mine but is to small.
    The filter I need is 7.5" tall & 4.25" dia . See the canister on the right hand head
  10. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Try Wix. Better filter anyway. Is there a # on your old filter?
  11. tommy
    tommy
    That is not a Ford filter. Pull the filter and look for a brand and a number on the filter. Armed with that info, a good parts store should be able to match it up with their brand and pt no.
  12. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Hastings premium filters,, Pt. # LF101
    I've got one if you don't have any luck, you can also get them from Mac's auto parts
    in Lockport, New York.
  13. tig master
    tig master
    from up north
    NAPA #1006
    Motorcraft #FL25
    Wix #51006
    Fram #C4
    AC #P209
  14. fenderless
    fenderless
    from Norway
    As tommy says, that canister don't look like a Ford canister!?
  15. Mr48chev
    Look at a cartridge filter for a Chevrolet. They are a tad over 4 inches in diamter and just over five inches tall and that would leave room for the spring.
    About all I can say other than that is to go to a NAPA or a store that sells Wix and get in their filter catalog as it will show the dimensions of the filters.
    If you have the old filter so much the better even if it doesn't have any numbers on it.
