who has shaved the firewall on their car?? what gauge metal did you use?? how bout some pics?? thanks.
I am getting ready to get mine straigtened out. Lookin at 16 ga. probabally. Maybee 18. Whatever I can get a fair price on given the current steel prices! FONZI
Most firewall's are 16 gauge. If you make it totally flat it'll act like the bottom of an oil can when it heats and cools with motor heat. That is, if your running a hood. The Wizzard
I had no choice because some speed freak butchered my firewall before I bought the car. I'm pretty sure I used 18 gauge, but as you can see from the inside photo I left much of the perimeter of the old firewall intact. It's solid as a rock, no oil canning here.
when i got rid of the stock heater i filled and smothed my caddy fire wall with 16 gauge only because of the big flat area.
Heavier could help out. Are you talking about an over lay like Crush 1776 or a complete new firewall? What kind of car are you working on? The Wizzard
In that case I'd probably just use 18 gauge. Will the master and heater still be mounted on it? I'd also use some panel adheasive to attach it instead of welding it on. The Wizzard
heater is gone. master will be on it for now. i will prob. weld it around the edges and then maybe spot weld it in a few places that are kind of hidden and out of sight. later. thanks.
I like em.. They can really clean up a car's look. I guess it depends on the look you're going for... 16 ga on mine.
