Engine seized 2 miles after rebuild
Discussion in 'The Hokey Ass Message Board' started by Merc cruzer, May 30, 2011.
  1. Truckedup
    Truckedup
    Glad you got to the problem and it's bad but not the worst.
    Better issue a service bulletin on the Flatty V-8 timing chains locking up engines...:D
  2. George/Maine
    George/Maine
    Was the crankshaft reground or standard.I looks like rust on crank,there may have been rust on jernals,but the wear in looks like the main cap got mixed with another motor,some thing to check.
  3. Unkl Ian
    Unkl Ian
    Good question.
  4. Merc cruzer
    Merc cruzer
    from Colorado
    George...the crank was .030 under to begin with. The machine shop confirmed that it was good even at .030 under so it was polished. I took it out of my other engine and there were no issues with oil pressure or balance, just the issue of the crack between the exhaust and the cylinder in number 3, causing overheating. Obviously the crank will not be reused again...so now I am on the hunt for another 4" Mercury crank.
  5. hotrodtom
    hotrodtom
    Amen to that. The inside of a fresh rebuild should look surgically clean. It is apparent that whoever did final ***embly left a lot of machining trash in oil p***ages etc.
    BTW -- did you check out the very easily visible crack between a water p***age and a stud hole on the deck surface? Is this your "new block" or the cracked one?
    Fearless
  6. Did not know flatheads don't have timing chains, good to know. :)
    Must have had a big oiling problem to seize up in 2 minles, that's like 5 minutes of driving. Last time I seized a main it made noise before it went... squealed.
  7. Just get that one welded up and reground. You know its a good crank and you don't know what you are buying. Or you could buy a **** crank for what a good merc crank is going to set you back.
    Oh and after the catastrophe it probably wouldn't hurt to have the main journals sized. It is a good practice to do even if you know you have a good block to build.
  8. rodnut1
    rodnut1
    Regarding the comment on deck cracks- I'm not seeing a pic of the deck surface, but as for cracks between coolant holes and head bolt holes on a flathead Ford block, they're so common they should have part numbers. 95% of them are absolutely nothing to worry about.
    The first pic of the main insert shows a very bad alignment problem that needs to be adressed. The crank was only contacting on one end of the shell- something's definately wrong there, for sure!
  9. roseville carl
    roseville carl
    hummmm did you put the center main in correctly? if you put it in wrong that will happen..........
  10. hotroddon
    hotroddon
    Look at post #29
  11. 8-Track
    8-Track
    It looks kind of dirty for a fresh rebuild, but maybe i am just a bit ****.
  12. I've never been inside of a flatty, but are there also oil holes on the shells that are still in the block? The shells in the main caps have holes in your pix. Are they redundant or did the guy install them wrong and there was no pressure to the mains?
  13. Kilroy
    Kilroy
    from Orange, Ca
    They have holes in both halves usually...
    If everything checked out fine before the rebuild (plastigauge), and you had good pressure... I guess it has to be a blocked p***age...
    Or could it have been the oil pump? On a flatty, isn't there an internal valve in the pump to direct the oil to the mains? Or am I thinking of something else?
    Did you do any of the 'full flow' mods on this block/pan?
  14. rodnut1
    rodnut1
    How did I miss that? Anyway, that particular spot is a very common crack in these old blocks. Most of these coolant hole-to-bolt hole cracks occured early in life, again nothing to be concerned over. I will usually helicoil these bolt holes for some added strength when torquing the bolts. Otherwise, not a problem.
  15. Merc cruzer
    Merc cruzer
    from Colorado
    That picture was the old block with the heads off.....before I dissembled it<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
  16. Merc cruzer
    Merc cruzer
    from Colorado
    This is the block just before I took it in to be magnafluxed
  17. Mr48chev
    I'm going to ***ume that you did all the cleaning on the block. When you first got it did the oil stains and maybe crud on the main caps match the rest of the inside of the engine? Most of the time before a block gets cleaned up you can see telltail signs that show that the caps were in that location or something doesn't jive because the oil stains and engine crud doesn't match between the block and main caps.
    Did you have the main bores miked?
    Did all of the bearing tangs match up with each other. Every engine I ever worked on had both bearing tangs mating up when you ***embled the engine. Put a cap on backwards and they don't match up.
    If you have an oil pump primer I think before I pulled it down (you can do this on the engine stand) I'd pull the distributor and with a can or pan with enough oil to immerse the pickup screen I'd spin the oil pump and see if oil is getting to the mains. It will run out over the crank if it does. No oil there and you know that somewhere in the oil p***ages there is a problem. that could be something blocking a p***age or a missing plug letting all the oil run right back in the pan.
    Keep us posted. I don't really think that the used pistons are that big of deal as some of these guys are hollering about. Mickey Thompson wrote about boring blocks to fit used pistons in his book Challenger. He was running Flatheads in the 50's then and racing with the motors. Go to any bull ring dirt track and half the engines out there on Friday or Saturday night are running pistons that have been in more than one block.
    At least you should be able to turn the crank to get the converter bolts out now.
  18. Merc cruzer
    Merc cruzer
    from Colorado
    Mr48chev:
    Here is the engine when I got it from the salvage yard. Not sure if the machine shop miked the bores. The bearing tangs did match up. Thank you for the oil primer suggestion..I will do that. I wish it had been covered here before I started the engine rebuild. I tried to ask and read about everything I could before I started. This is my first flathead but not my first engine.....Porsche, Jags, MG's & Triumphs before...never with an issue.
  19. George/Maine
    George/Maine
    I would check to see if you may have mixed the main caps.Look like the better one must be the front,wear is wrong and if not dirt its wrong cap.Wrong meaning another engine parts.
  20. By the look of that front bearing, it appears that this journal has taper or is out of round if you look at the wear pattern on the bearing itself. ie: the front half of the bearing is shiny from wear...the rest of the bearing's surface is as installed.
    From experience, there are so many crank "machinists" who take the at***ude "near enough is good enough" when it comes to preparing crankshafts.
    The centre looks like it may have been too tight and that it was a matter of time before the lack of clearance became too much.
    What do the rod bearings look like ?
    Rat
  21. Raven53
    Raven53
    from Irwin Pa
    Yup that would do it
  22. Merc cruzer
    Merc cruzer
    from Colorado
    Rat bastad:
    Haven't pulled the rod caps yet...stopped when I found the main fried...
  23. tig master
    tig master
    from up north
    Remove "dist" spin pump to see oil pressure ??? WTF.
    Oil pump is driven from rear of cam with idler gear "spin pump" is not gonna happen this is a flathead boy's.
  24. Atwater Mike
    Atwater Mike
    Right on, Mr. 48. On the rod tang issue, however there is some Off Topic info: BMW 1600, 2002 four cyl. engines (and some early sixes) ***emble rods with the bearing tangs opposite each other.
    (Just a 'tab' of info here, nothing else. I was surprised to learn that after a thousand flatheads, Chevs, Jags, Y-Blocks...well, you know.)
  25. seb fontana
    seb fontana
    from ct
    ""If you have an oil pump primer I think before I pulled it down (you can do this on the engine stand) I'd pull the distributor and with a can or pan with enough oil to immerse the pickup screen I'd spin the oil pump and see if oil is getting to the mains. It will run out over the crank if it does. No oil there and you know that somewhere in the oil p***ages there is a problem. that could be something blocking a p***age or a missing plug letting all the oil run right back in the pan.""
    I don't grasp how you do the above with a flathead..
  26. tig master
    tig master
    from up north
    In your ford barn post you mention that the block has been drilled for a 95% filter. Not according to your pictures in this posting or at least not completed.If it was only half done they may have put the grub screw in the horizontal p***age and it was missed this would lead to the two mains starving for oil as the rear main is oiled independently from those two.Look in horizontal oil gallery for the offending grub screw.
    Tig
  27. Merc cruzer
    Merc cruzer
    from Colorado
    Tig Master:
    Just a thought...take an old gear off of the rear of an old cam...weld it backwards to a piece of pipe that you can chuck into a drill. Pull the cam and the back cover and use the new set up from the back to power the pump....it seems that this should work if you only want to test the oil pump inplace?
  28. Merc cruzer
    Merc cruzer
    from Colorado
    Tig Master:
    That was an early picture....here is a current one...
  29. BHT8BALL
    BHT8BALL
    Check to see if the oil holes in the front & center cam bearings are inline with the vertical oil p***age going from the oil gallery to the mains. The oil flows from the gallery to the groove in the camshaft and then to the mains. If that's ok I would check the flow from the pump to the gallery, maybe something didn't get drilled or ***embled right, which would still allow oil to the rear main.:confused:
  30. tig master
    tig master
    from up north
    That's better now.Remove the allen plug from the horizontal p***age the one that has some green paint on it closest to your external oil line insert a piece of coat hanger it should go in as far or further than the other allen plug that has been put in the horizontal hole that was drilled and tapped.
    This will confirm that the grub screw is not i there If doesn't go that far the plug is in there and has starved the rest of the engine. You could pressureize the oil port with a pre lube system and confirm oil to the rest of the engine but report back first on the grub screw.
    Tig
