Projects The Goon Wagon build--Wheelchair accessible F-1
Discussion in 'The Hokey Ass Message Board' started by TexasDeuce, Sep 26, 2009.
  1. Da Tinman
    Da Tinman
    I would.:D
  2. cowboyinachair
    cowboyinachair
    from colorado
    yeah cuz if it didnt work u could stand up and walk away
  3. Da Tinman
    Da Tinman
    Wow. Sorry to have pissed you off.
    The offer is still open though.
  4. merc546
    merc546
    from Michigan
    Hi, If the problem is only entering have you thought about having a section of the roof over the rear doors raise (hinge) after the doors are open. So he would gain some head room for entering.
    Chuck
  5. Sinister
    Sinister
    from Oregon
    A visual of my thought...
  6. Sinister
    Sinister
    from Oregon
    If the rear door height is an issue, when you raise the skin, make the back resemble the rear roof scoop like a '58 chev, only a little bigger. Then you can open up the rear for entrance clearance. See the attached pic. The red dotted line would be the new door mods. Sorry for the ****py sketching, just wanted to get the idea across.
  7. TexasDeuce
    TexasDeuce
    Merc -- The builder thought of that but then the issue of water leaks. We currently have a full size van with a Turtle Top and that leaks every now and then.
    Tinman -- thanks for the offer but I am not sure if working on the chair might void the warranty. It is an expensive chair and we rely on help from tech support to deal with the Bluetooth issues we have every now and then. Another thing is it has some kind of gel batteries below the seating system and the seat platform can't be moved any lower see pic.
    Sinister -- The builder thought about going this route and kept referencing a toy from the 60s that looked kind of like that but then they raised the concern of structural integrity.
    So they recommended going with dropping the floor 4 more inched to where the floor is just above the center of the rear axle. Then adding the Air Ride system to lift it up when we drive.
  8. thebugbox
    thebugbox
    If money is no issue (I'm sure it is) Cadillac Northstar v8 with front wheel drive, then put trailer torsion rear suspension. Would free up a lot of space.
  9. cowboyinachair
    cowboyinachair
    from colorado
    in a old hot rod mag i had they used a cad eldo front end with a 500cid in a 56 ford school bus
  10. TexasDeuce
    TexasDeuce
    yea well, money is an issue. what can i say. we already have and SBC 350 4 bolt main and a 700r4 trans in there now so i pretty much gotta work with what i have.
  11. dirt t
    dirt t
    Any new progress?
  12. TexasDeuce
    TexasDeuce
    No new updates. The ride is back in storage. Things went south with our builder and we had to bring our ride home and re***ess where we are and what we need to do to get this done.
    We are going to have to look for another builder to finish this project. It is not by any means on the back burner. I have to get this finished and cruising with my son in it ASAP. We are racing against time and a health condition that results in a short life span for my son.
    I am running out of time so I am pressed to fulfill his dream of having his own hot rod.
    Hopefully we can get back in a shop and being worked on this summer.
  13. Special Ed
    Special Ed
    I thought this was an ingenious solution for what you've described....
  14. TexasDeuce
    TexasDeuce
    wow! Very nice! do you have any more pics or info on this ride?
  15. TexasDeuce
    TexasDeuce
    UPDATE!
    We found a new builder that has taken on the task. He has been building cars for quite a while and is a stand up guy. We took the panel to his shop to re***ess what we need and what we have to work with. He told us the floor cannot go any lower so we will have to work on the roofline like it has been mentioned above.
    The roof is going to be sectioned at the entrance just above the doors.
    The floor will be cut and leveled off to be smooth. This will make it easier to for my son to turn and exit facing outward.
    New concept for paint has beed redone as well. See last pic.
    More updates as they develop.
  16. This is how Renault did it with their little vans.
