428 cj and a cruiso need help
Discussion in 'The Hokey Ass Message Board' started by thunderbird paul, Jun 1, 2011.
  1. thunderbird paul
    thunderbird paul
    from ohio
    engine runs great but problems with ****** its a fresh rebuild and i can go threw all the gears and nothing happens at the rear end any suggestions
  2. Deuces
    Deuces
    Ummmm..... Hook up a driveshaft??? :rolleyes:
  3. 56don
    56don
    You didn't hear a pop when you bolted up the transmission did you? If you didn't bolt it up right you could break the pump. Hard to diagnose with little info.
  4. Heo
    Heo
    Did you mounted the converter on the trans first?
    if you mounted it on the engine big risk of break the pump
    do you have reverse?
  5. stillrunners
    stillrunners
    from dallas
    does the drive shaft turn?....just sayin'....
  6. rkwilsonjr86
    rkwilsonjr86
  7. thunderbird paul
    thunderbird paul
    from ohio
    the drive shaft is in and spins freely with the when i turn the wheels
  8. thunderbird paul
    thunderbird paul
    from ohio
    i did not here any pop when on real easy i also filled the converter and put it in the bell housing before i put the trans on
  9. thunderbird paul
    thunderbird paul
    from ohio
    i also bolted and torqed the converter to the flywheel after i torqued the trans bolts and the rear end is not froze up
  10. thunderbird paul
    thunderbird paul
    from ohio
    any other sugestions i have been told that old trans need a little time to prime themselves i dont know this is my first trans rebuild thanks for answering
  11. JOHNPO
    JOHNPO
    did you install the input shaft..it slides into the front pump...i did it a long long time ago will never do it again....
  12. thunderbird paul
    thunderbird paul
    from ohio
    yes i did it was the first thing i put back in the case when i was rebuilding it and then after it all was together i put con,erter on and it slid on real easy once i lined the teeeth up
  13. GassersGarage
    GassersGarage
    When you put the converter on, did you spin it until it seated on the pump?
  14. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Shift through all gears and check fluid level,With brake applied
  15. Blk210
    Blk210
    from New Market
    Did the converter drop twice? A little at first and then again after spinning it some, also if it's not to much trouble drop the pan and check the lever, had one loosen up and then slip to the whenever put in gear.
  16. thunderbird paul
    thunderbird paul
    from ohio
    i did spin it till it droped in twice i checked the lever when i put new seal in it . i am going to let it run tomarrow for about an hour and try it again i was told this will make sure all the fluid is nice and hot and threw all the lines and trans coolerhope this works i need to start to break in motor since it is a freash rebuild too
  17. Ebbsspeed
    Ebbsspeed
    While the above statement is a bit scary, you did say you spun the converter until it moved back twice (once is clearing the seal, the second is the engagement of the front pump) so you may be OK. I'd bet on low fluid. Even though you filled the converter, there was likely a lot of airspace still in it that might have used up all of the fluid that was in the pan once you started the engine. How much total fluid have you put into the trans and converter?
  18. thunderbird paul
    thunderbird paul
    from ohio
    i put 2 quarts in canverter before i put it in and the fluid level was rright at the bottom of the shaft that goes into the inputshaft and then i put in 5 quarts into the ****** i never draind the converter during rebuild cause the fluid was still good not burnt smelling or dirty
  19. railroad
    railroad
    Loosen one of the cooling lines while running and see if you have any pump pressure. You will need this first to move. If no pressure and you have not been in the trans, probably a pump. If you have pressure, the valve body directs it to the correct area. See if the linkage is actuating the valve body. You should have something in one of these areas that is causing the problem.
    good luck,
  20. thunderbird paul
    thunderbird paul
    from ohio
    thanks everyone the help is great.
  21. thunderbird paul
    thunderbird paul
    from ohio
    railroad the only pump is in the convertor right
  22. thunderbird paul
    thunderbird paul
    from ohio
    i ran the car for an hour and nothing happened with ****** any ideas i am leaning to a new converter now but dont know where to start looking for one
  23. Ebbsspeed
    Ebbsspeed
    After running the engine for a while, did you check the fluid level on the stick with the engine running? You said you filled the converter until the fluid was level with the shaft. That's basically only half full. So you would have used at least two of the five you put in the pan to fill the converter up full. The trans being a fresh rebuild is dry, so you'd have easily used up a bunch more of the fluid in the pan just filling up all the different hydraulic areas of the trans. A Cruise-O-Matic and it's torque converter have a fluid capacity of somewhere around 11 quarts. I still think you're low.
  24. Engine man
    Engine man
    from Wisconsin
    The dip stick tube extends into the case to shield the stick from splash oil so you can tell the level. I have seen people cut some off to get it back in then the oil level always shows high. One way to check it is to remove the stick with the engine running, wipe it off, be ready to stick it in and have someone shut off the engine. When it stops turning, quickly insert the dipstick and pull it back out.
    I think those transmissions took at least 9 quarts of fluid or more.
  25. railroad
    railroad
    No, the front pump bolts into the front of the trans, inside the bellhousing. With the torque converter out, you will see a round flange with bolts around the edges. I cannot remember for sure, but it seems there used to be a gasket lip around the edges. Anyway that is your pump. Sound like you did everything right with the install. If you have enough fluid and you have pressure on the cooling lines?? I'm still thinking the valve body linkage did not line up with the external linkage. If you get to the point you have to drop the pan, you can see if the valve body slide valves are moving with the shifter linkage.
    The input shaft connects the converter and drive mechanics of the trans. If the fluid is getting hot it is being pumped. I just re read some of your input. Pull the pan before you pull the trans. If you pull the trans check the input shaft.
  26. thunderbird paul
    thunderbird paul
    from ohio
    Ok ya I remeber that part t put a oring seal back in it. Ok I will check fluid level tomarrow thanks again I will keep informed
  27. thunderbird paul
    thunderbird paul
    from ohio
    railroad when i put the valve body back in i put the shift linkage in the last spot on the slide and i put the kick down linkage between the stop and the slide was that right i think it was. thanks
  28. thunderbird paul
    thunderbird paul
    from ohio
    ok guys i went out and checked out fliud levels and then i took off a ****** cooler line to see if i was getting anything and there was no fluid in the lines or in the cooler. so what now. is it the convertor or the pumps . i dont know how the pumps work so i dont know where to start thanks again
  29. railroad
    railroad
    The spline on the outside of the front pump engages with the inside of the torque converter. It is direct drive to the front pump. Sounds like you are not pumping.
    When and if you pull the trans, you will need to make sure the tq conv engages the
    outside spline on the pump shaft and as you turn the tq conv, you are turning the
    front pump. I am by no means an auto trans mechanic, but I have worked on my own.
    I am a ford guy, so I have been around what you are working on. This is a long shot and
    you may not want to try it, but I think the cruis o has a front and rear pump. This means you are able to push the car off to start it. Best I remember you have to exceed 35 mph to have sufficient pressure to transfer it all to the engine. In the event your front pump is the problem you could push or pull it off. Beware if you stop you are dead until the driveshaft starts to turn again. With no line pressure either the pump is not working or the valve body is not right. I put a shift kit in once and got no pressure. Problem was a c-4 kit into a cruis o trans, did not work,pump was OK. I just have not heard of many pumps going bad, unless they were run dry. I had a Ford o that a snap in tube on the valve body popped out and all the front pump pressure was lost, as the car coasted down a hill the rear pump made pressure and it was driveable, until I stopped and pulled the pan.
    That's about all I got with the info.
    Keep plugging and let us know what you are doing.
  30. thunderbird paul
    thunderbird paul
    from ohio
    Thanks railroad will keep up to date I am going to call a trans shop on Monday. A budy gave me phone number so I gonna call and c what they say
