I have a C4 and it shifts hard and takes a while to shift from gear to gear, it down shifts hard as well? Should the modulator valve be hooked up to vaccuum that increases with throtle or constant vaccuum? I have edlebrock carbs and I do not run a kick down. The trans works fine otherwise. Thanks
I can't speak to specifics, but in generalities, you do NOT want to run it for any period of time out-of-tune. There's about an 1/8ths of a gnat's ass worth of friction material in there and it takes almost nothing to burn through it.
99% you have a modulator issue, yes, manifold vacuum, and you should be running a hard line except for the ends. Check for a cracked or broken hose where it goes into the modulator itself, and this hose should have a molded curve in it.
is the small pin behind the modulator in there? Mine did similar things and when I pulled the modulator there was no link pin. did some googling and made one from piece of weld rod, all better now.
