The Hot Rod God in the sky smiled on me...(37 Dodge Update)
Discussion in 'The Hokey Ass Message Board' started by Brad S., Apr 24, 2005.
  1. Brad S.
    Brad S.
    I bought this car in Dallas on March 1st.
    It barely ran....It would barely move....it smelled like piss...
    When we got it to Houston we started to tear it apart.
    The Radiator was held in with tie wraps. The grill was just sitting in the frame and was "secured" to the upper radiator hose with bailing wire.
    Fixed that stuff.
    Had the leaking radiator repaired.
    We fixed the lights, horn, and traced all the pertinent electrics to make sure they were fixed. We had the wiring harness strung all over the garage.
    I was told that it had a broken shock mount. I verified it. I didn't notice that the upper control arm for that side was broken at the frame....along with the shock mount....which meant that the drivers side rear end was held with one bolt.
    Fixed that stuff.
    I thought I was close to done. That is until I changed the spark plugs....and the flex plate started grinding on the starter. Three starters in a week and a half and figured I needed to pull the engine anyway.
    Thought about changing the SBC our for something else at that point. Family talked me out of it since this was my first Hot Rod project in almost 15 years. Rebuilt the SBC. Rebuilt the carb.
    Last weekend we got the engine put back in. Got it running on Tuesday. Tweaked and twisted and fine tuned everything I could before today.
    ...and yes it got hosed in very flat black. That stuff is good for hiding all the bodywork which will get done.
    A little timing...
    A little adjusting...
    A little water in the radiator seeing as how I forgot to fill the damn thing...
    I finally took the first of many test rides this afternoon. w00t!
  2. Merge
    Merge
    WOW! There is something about that car that just does it for me! I remember seeing your post back when you got it and I jst loved the way it sits. Nice work and best of luck with it!
  3. Missouri_Mike
    Missouri_Mike
    Congrats on getting it running....and isn't it nice to know that you're not going to see another one at every rod run and cruise that you go to? :D
  4. FiddyFour
    FiddyFour
    OH YEA! :D
    this is a fine ride!
  5. Flathead Youngin'
    Flathead Youngin'
    Looks like lot's o fun! I like that!
  6. Ya know usually I don't like yellow, but it works on that car...nice work!
  7. Upchuck
    Upchuck
    from Canada BC
    Nice!
    you did all that in under 2 months? I wish I had that kind of work ethic:D
  8. Brad S.
    Brad S.
    It was not so much "work ethic" as it was "obsessing" to get it running.
    My wife has started calling it "the bitch in the garage".
    The coolest thing?
    Every issue I had...every little problem....was answered with the search function on this board.
    So thanks to everyone!
  9. 4woody
    4woody
    That's a fine looking body style. Look good with the fenders or without!
  10. Orange54
    Orange54
    from Missouri
    Did you get that pis smell out?
  11. Brad S.
    Brad S.
    It was a blanket thrown over the package deck.
  12. KoppaK
    KoppaK
    Are you gonna build it early "Westergard Style", are ya, huh,huh go on? Would it help if I said please?
  13. G Griffin
    G Griffin
    Looks mean and nasty!
    Good work.
    That neighborhood looks familiar...
    G.
  14. aedan
    aedan
    from ###
  15. Chandler
    Chandler
    from Rowlett,TX
    that is a cool find ya got there
  16. edsel
    edsel
    Damn I like that !!!!! sweet!!
