Used Plasti-dip for sound/heat barrier?
Discussion in 'The Hokey Ass Message Board' started by dccd, Jun 5, 2011.
  1. dccd
    dccd
    from Missouri
    Has anyone used Plasti-dip as a heat and/or sound deadener in their rides? Just found an old spray can of the stuff I had forgotten about and was just wondering. The can says it will work for this purpose. Thinking about spraying a s**** piece of sheet and seeing how it does as a heat barrier.
  2. mrjynx
    mrjynx
    I was interested in this as an underbody sealant
  3. badshifter
    badshifter
    No, but I used Dynamat on my vise grip handles.
  4. nofin
    nofin
    from australia
    Plasti-dip gets soft and flexible and can come off what it's painted on when it gets heated. And it really stinks when it catches fire.
  5. dccd
    dccd
    from Missouri
    When it gets heated?? The propaganda on the can says it can be used in a heat insulation application. Any idea on the amount heat you're referring to to make it get soft and come off? Really want to know if I should be concerned using it on my firewall, or anywhere inside the car. ***ume windows are rolled up and it's a typical MO summer of a few 100+ degree days.
    And if my car does catch on fire, any stink coming off it will probably be fairly far down the list of things I'm concerned with at the time. :D
