Hot Rods What is this called?
Discussion in 'The Hokey Ass Message Board' started by Tenacious A, Jun 10, 2011.
  1. Tenacious A
    Tenacious A
    from Willis Tx
    The proper name for the piece covering the frame under the door?
    Jim
  2. Bob K
    Bob K
    from Antigo Wi.
    Splash apron
    B:)B
  3. Nevala
    Nevala
    Fenderbergs!
    (Running board apron)
  4. HammerDown
    HammerDown
    running board apron
  5. Butch/1
    Butch/1
    from Dublin ,Va
    I agree with Bob K
  6. 1932tub
    1932tub
  7. Ugly,if you leave it on without the fenders.
  8. MrModelT
    MrModelT
    Splash Aprons
  9. 117harv
    117harv
    COOL, if you run it without the fenders:D
  10. Harms Way
    Harms Way
    "Splash Apron",....
    Not to be confused with the "Original splash apron"
  11. JBOLTON
    JBOLTON
    :D nice 1
    but yes,,,,, splash apron.
  12. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    splash apron. I have 2 sets for a 29 and a single 30
  13. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I agree with zombie ,Splash apron to conceal saddlebag tank
  14. koolkat269
    koolkat269
    Henry didn't use saddle bag tanks in 1928
  15. Dirk35
    Dirk35
    Slash Shield,
    Slpash Apron,
    Running Board Apron.
    When you search for them, depending on the manafacturer, itll be called one of the three. The radiator splash apron also has a few names depending on where you look.
  16. gnichols
    gnichols
    from Tampa, FL
    It's the "had to put it back on because I didn't realize how ugly the A's frame would be on my highboy until later" apron.
    Or, the "should have channelled my body instead" apron.
    Gary
  17. C.U.S.P..... (cover ugly **** panel)
  18. idunno but did you really stick a dynamo label on a photo and scan? cause thats funny all in its own if ya did.....
  19. 2-TONED
    2-TONED
  20. J'st Wandering
    J'st Wandering
    That would be the traditional way to do it. :)
  21. built2grind
    built2grind
    I've always called those "junk" Get rid of them as fast as you can.
  22. 117harv
    117harv
    What, A frames are ugly, when did this happen:eek:?
    I think the splash aprons look allright...on the right car:)
  23. Model A Gomez
    Model A Gomez
    Splash apron, car would look better if you pulled it off.
  24. Hnstray
    Hnstray
    from Quincy, IL
    While we're dealing with correct terminology here, it's "dymo" label, not dynamo......a dynamo is a another name for a generator :D
    Ray
  25. Thats a splash apron. On a fenderless car that a VERY pre-war look. I have pics of my grandfathers roadster from the late 30's fenderless with splash aprons. It was cause it made the fenders easier to put on back on when you got a ticket. He told me the cops would give you a ticket you would put the fenders and running boards back on with a few bolts and then get your ticket signed off, then rip them back off, throw them behind the garage and wait to get caught again! LOL
  26. phoenix5x
    phoenix5x
    from Ohio
    brookville considers them "running board aprons"...so if you lookin for replacements then thats what u would ask for but splash aprons would work as well...sure most people would know what ur talkin about...
  27. gnichols
    gnichols
    from Tampa, FL
    And on cars raced (primarily on the flats), where you'd strip down your car to race it, and then put the fenders, bumpers and all the rest of the stuff back on before you drove home. It's just too hard to remove the aprons (gotta lift the body, right?) to save the weight of the aprons, eh?
    Gary
  28. thePAkid1931
    thePAkid1931
    from Eastern PA
    That's not a 1928! It's a 30-31
  29. Ned Ludd
    Ned Ludd
    "Rocker panel" describes the ****ogous bit in pontoon body cars, especially post-c. 1963, when many cars had a character line around hub height. I've heard the earlier panel described as a rocker panel before - I think in relation to upmarket coachbuilt cars - but when I posted a question about them on the Ford Barn using that term I was met with so much confusion that all the attention was drawn to the terminology and my question remained unanswered.
    For what it's worth, can anyone tell me the width between the vertical parts of the aprons when installed on a later A? Are they parallel or do they taper to the front?
  30. Weasel
    Weasel
    Says he with a photo of a Model A with them on in his avatar....:rolleyes:
