Projects Ford Truck Build ++PICS++
Discussion in 'The Hokey Ass Message Board' started by Martin_F, Dec 1, 2008.
  1. 3"
    40.7%
  2. 3 1/2"
    14.8%
  3. 4"
    44.4%
  1. Martin_F
    Martin_F
    No, I am not done with the chop yet.
    Right now I am focusing on ch***is and drivetrain so I can at least drive her this summer.
    Might not be the most beautiful truck then, but at least on the road!
  2. Martin_F
    Martin_F
  3. Martin_F
    Martin_F
    First, I have to apologize for being to lazy to update this thread in a long time.
    I didn't realize that there was quite a few people following this thread.
    Second, I figured I'd continue this thread and not start a new one, or continue with the one linked above.
    So we left off running brake lines and fuel lines.
    The original plan was to get the frame finished and powder coated, so I wouldn't have to touch it anymore and could focus on the cab.
    Good thing I changed the plan, because when I was trying to install the master, I noticed some clearance issues. Seemed like the master I used for mock up had the line fittings in different locations than the one I was gonna use.
    So here is the fix for that:
    Next was to fab a new dash insert to house my New Vintage USA gauges:
    Then I started welding up the exhaust byp*** including the Smitty's gl*** packs:
    Pretty much one of the last things to do was making a gas filler tube.
    I kinda like how this turned out, and it is one of the few parts I consider to get chromed:
    Then I just sprayed some rattle can black on the body, because it was already December 2010 and I wanted some protection.
    Then I got everything wired. Unfortunately I couldn't get any help on this job so it took forever, but finally after calling Rebel Wire a couple of times I got everything working.
    I used their 9+3 circuit wiring harness and I am really happy with it.
    So then it was sitting in the garage, ready to be released:
    I really would have liked somebody that knows what's going on to be there, when I first drove it down my driveway but that didn't happen.
    So I just waited for all my neighbors to be gone for work when I finally took the chance.
    My driveway is pretty steep, and there was now way of knowing if the brakes would be strong enough...
    And then the big moment I have been waiting for over two years:
    Here are some pics of it sitting at the bottom of my driveway:
  4. Martin_F
    Martin_F
    So that was on December 22nd of last year. Since then I was trying to work all the bugs out and that's what I'm still doing at this point.
    I've made a few longer trips since than, like going to one of OJ's Shop gatherings in Berryville VA:
    Took the chance on the way home to take some pictures on the side of the road:
    Next trip was on the Blue Ridge Parkway:
    I changed the original Rochester Q-Jet carb and electric fuel pump I was running to a new Holley and mechanical fuel pump. One of the better changes I did!
    Also I've been asked to become a member of the HEAPS of Old Dominion Car Club, which I'm very proud of. These guys are just the coolest guys to hang around with!
    So the most recent trip has already been covered by Dave in this road trip thread:
    http://www.jalopyjournal.com/forum/showthread.php?t=593617
    So I'll post just a few more pics here:
    Next up is to address the wobble I get up front at higher speed.
    Changing the caster angle didn't help, so I'll look into steering and most likely change my cowl steering setup to a traditional F100 steering setup.
    Thanks for listening, and I promise it won't be as long for the next update!
  5. DaveInc
    DaveInc
    Nice work Martin!
  6. 1929
    1929
    from Pomona
    Looks *****in!
    sub.
  7. Martin_F
    Martin_F
    Thanks guys, appreciate it!
  8. chrisntx
    chrisntx
    from Texas .
    It will be nice to get a 1935 license plate to match your 1935 Ford Truck Cab.
    "Next up is to address the wobble I get up front at higher speed."
    Measure your wheelbase on each side, make each side the same to eliminate the wobble
  9. ClutchDumpinDan
    ClutchDumpinDan
    Great to see an update, your truck is *****in! :D
    Are you gonna make the ride to Richmond on Saturday?
  10. Good stuff Martin! The truck looks great and congrats on being in the Heaps!
  11. Martin_F
    Martin_F
    Thanks, guys!
    Dan: The plan is to be there, but I'm not sure on the details yet.
    Mike: Love your truck! Hope to meet you in person one day!
  12. Thanks Martin! That means a lot!
    And likewise on the meeting. You and the Heaps need to make a trek to the HAMB Drags one day!
  13. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    Martin
    Wow. That 36 is a beauty.
    Truly inspiring and motivating.
    I will update my 37 pics this weekend.
  14. Landmule
    Landmule
    Man that's cool. Very inspiring thread!
  15. Martin_F
    Martin_F
    Thanks guys!
    Stole this idea from Mike, took a little video on my trip to a car show today.
    Nothing mayor.
    At the show, spectator parking lot:
    Home after a long day:
  16. That was a fun ride Martin! What kind of camera? mount are you using? Go Pro?
  17. Martin_F
    Martin_F
    Yes, it was my brothers go pro with a big suction pad on the wind shield.
    I still need to figure out how to mount it to the grill looking back...
  18. AnimalAin
    AnimalAin
    Neat hot rod. Now get out there and wear it out.
  19. knotttty
    knotttty
    Great job fuxl..... I hope mine turns out 1/2 as good as yours.... I have enjoyed following your build from begining to end...
    Roy
  20. Martin_F
    Martin_F
    Thanks again, guys!
    Made another trip on the parkway:
    Video is still to come...
  21. Martin_F
    Martin_F
    Finally got to play with my new Video editing software:
    <object width="400" height="225"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=31516757&amp;server=vimeo.com&amp;show_***le=0&amp;show_byline=0&amp;show_portrait=0&amp;color=00adef&amp;fullscreen=1&amp;autoplay=0&amp;loop=0" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=31516757&amp;server=vimeo.com&amp;show_***le=0&amp;show_byline=0&amp;show_portrait=0&amp;color=00adef&amp;fullscreen=1&amp;autoplay=0&amp;loop=0" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="225"></embed></object>
  22. Nice Martin! That was fun!
  23. DaveInc
    DaveInc
    That was great Martin!
  24. iwanaflattie
    iwanaflattie
  25. Martin_F
    Martin_F
    Thanks guys, that means a lot!
  26. Martin_F
    Martin_F
    Sure thing! Plus i was wearing the hat too ;)
  27. Martin_F
    Martin_F
    No, I won't. Took me to long to get back on my feet, and now I'm worried about not to get it done before then. Would be bad if the truck would still be in pieces and I couldn't go either. So it'll be a winter project.
    Hope Sam will change his mind. We'll see...
  28. Bar Ditch
    Bar Ditch
    from Tacoma
    Nice thread, awesome truck. Great job.LB
  29. ClutchDumpinDan
    ClutchDumpinDan
    That video rules! :D
    Looks like some great scenery for a fall pie run up that way.
  30. K13
    K13
    I totally missed this thread until now. Nice work on your build and cool video.
