Help me ID this bellhousing... thing.
Discussion in 'The Hokey Ass Message Board' started by DocsMachine, May 22, 2011.
  1. DocsMachine
    DocsMachine
    from Alaska
    And by "help", I mean "tell me what the heck it is". :D
    I have no info on it other than that we found it loose in the dirt (yeah, real helpful clue there, I know :) ) and it has a GM number on it (3742361) that only comes up with a single automotive-related hit on Google, that hints it's a 6-cyl/Powerglide adapter. (No photos, though.)
    Can anyone positively ID it? Anyone need it?
    Doc.
  2. propwash
    propwash
    from Las Vegas
    the small pin showing through the opening at the 10 o'clock position in pics 2 and 3 appears to be some sort of a timing pointer. Location of the starter holes precludes any application for late (40 on up) p***enger or light truck applications. Likely some industrial use - but this guess has to be tempered by the reference you gave for the part number - Powerglides have only been in use since early 50s - and nothing on that "adaptor" likes like any six cylinder in my memory banks.
    Intriguing problem - be interesting to see just how fast the HAMB takes to solve it.
  3. Stovebolt
    Stovebolt
    Easy :)
    Its a 235/261 Chev six cylinder cast iron powerglide adapter. The six specific auto trans bolts to this plate.
  4. ugotpk
    ugotpk
    It's for a F-n boat
  5. Hnstray
    Hnstray
    from Quincy, IL
    X2.....................
    Ray
  6. propwash
    propwash
    from Las Vegas
    just guess that shows how much I know about stovebolt sixes....now I'm educated...although I don't know how long that will stick
  7. DocsMachine
    DocsMachine
    from Alaska
    Sounds like there's a consensus. Thanks, guys!
    Now, does anybody need it? :D
    Doc.
  8. Mr48chev
    It's probably not a hot seller but you can be sure that somewhere along the line someone will be needing it.
  9. 40FordGuy
    40FordGuy
    Definitely 6 cyl Chev.....The give away is that timing pointer. There was a 1/8" ball pressed into the flywheel,.. to be aligned with that pin. 4TTRUK
  10. cdo1953
    cdo1953
    You guys are correct 235 chevy 6 trans adaptor for a powerglide
