427 mid rise heads
Discussion in 'The Hokey Ass Message Board' started by 390fe bomber, Jun 15, 2011.
  1. 390fe bomber
    390fe bomber
    does anyone know what all is gonna have to be done to a set of 427 mid rise heads to fit a 390?
  2. CNC-Dude
    CNC-Dude
    You need to make sure that the intake valves don't rub the tops of the cylinder walls, and notch the block if they are too close. And also you need to make sure you use the correct med. riser rocker shaft stands and a med. riser intake manifold will need to be used.
  3. 390fe bomber
    390fe bomber
    alright thanks, thats exactally what i needed
  4. Deuces
    Deuces
    How about some pictures of those heads if ya got'em??? Thanks! :)
  5. Relic Stew
    Relic Stew
    from Wisconsin
    Medium riser heads with 2.19" valves require too deep of a notch to work on a 4.05" bore block. They are usable with a notch on a 4.13" bore block. Low riser/428CJ heads with 2.09" valves will work on a 4.05" block without a notch, but the extra clearance will help breathing.
  6. Deuces
    Deuces
    That's good to know!! Thanks for the info! :)
  7. 390fe bomber
    390fe bomber
  8. 390fe bomber
    390fe bomber
    Definiatly good info to have thanks
