Aluminum cleaning ?
Discussion in 'The Hokey Ass Message Board' started by blue 49, Jun 19, 2011.
  1. blue 49
    blue 49
    from Iowa
    I've got a pair of vintage die cast finned valve covers I want to use on my 327 Chevy. I don't want to polish them but would like to "whiten" them so they are a closer to the appearance of my newer intake manifold. Any ideas?
  2. chaddilac
    chaddilac
    Bead blast them....
  3. racer32
    racer32
    Gl***-beading ruins a LOT of aluminum parts. Once they've been blasted the casting is never the same as it was before. Soak them in Berryman's.
  4. F&J
    F&J
    I use very worn out sand from the cabinet blaster. It's almost like dust, won't hurt the part.
  5. Fast67VelleN2O
    Fast67VelleN2O
    Napa Aluminum Wheel cleaner. All you need is a hose, a scrub brush, and whatever part you are cleaning. Comes out very natural aluminum. I use it on all my alum parts.
    -Matt
  6. A Boner
    A Boner
    Try using a S.O.S. pad.
  7. tjmercury
    tjmercury
    I used Eagle One aluminum "ETCHING MAG WHEEL" cleaner on my old fenton intake and it worked great. Just spray it on let it set and hose it off. You can brush them if they are really dirty, but I didn't hafta.
  8. With die cast stuff you might want to experiment with the strength of whatever "potion" you use, so it doesn't discolor.
  9. TexasDeuce
    TexasDeuce
  10. dontlifttoshift
    dontlifttoshift
    This
  11. 48 Chubby
    48 Chubby
  12. brad chevy
    brad chevy
    The Eagle One stuff is good.I used it on a set of Western turbine wheels and they cleaned up good,no dang scrubbing at all.
  13. lowpunk
    lowpunk
    from berwyn, il
    Carb cleaner, red scotch pad and elbow grease.
  14. Don Moyer
    Don Moyer
    Depending on how clean you want it, there is a cleaner at your local heat and a/c supply house for cleaning a/c coils. Works fast and really cleans them to a "white condition" with no effort. Put it on and spray it with a hose.
  15. blue 49
    blue 49
    from Iowa
    Thanks for the input guys. I'll try the wheel cleaner first. Hope it works out OK. Can't hurt, right?
  16. TheTrailerGuy
    TheTrailerGuy
    from my experience, any of these would work... but i just had to clean up an old '56 panhead piece and Mothers aluminum polish with a nice soft rag always blows my mind. I would post photos but fear that it might be off topic.
  17. fearnoevo
    fearnoevo
    from Iowa
    The eagle one stuff is great.
    Its muriatic acid, reduced to some percentage, not sure what.
