i'm doing a split wish bone for the rear on my project, i need the part # for the tie rod ends, i was told to use 3/4 in fine threaded tie rod ends off a 60's type truck but our parts stores in town won't bother looking up without a part# or exact truck or ch***is year, does anyone know what tie rod end works the best. Thanks
1948-'64 Ford 1/2 ton pick up tie rod ends. You want to use two that are right hand threaded for splitting your wishbones.
The thread size is 11/16-18. Available in right hand and left hand threads. Aftermarket company's offer the bungs as well as the correct tie rod ends and taps if needed. Check Speedway Motors. http://www.speedwaymotors.com/Wishbone-Splitting-Kit-for-Tie-Rod-Ends,41893.html
