Model A rear end suspension pictures wanted
Discussion in 'The Hokey Ass Message Board' started by Gabe4223, Jun 22, 2011.
  1. Gabe4223
    Gabe4223
    from texas
    I am finishing up my rod and I am trying to get some ideas for my rear end. I have spring coils in the back and everytime I turn it seems that my body is bottoming out. I'm going to add shocks in the rear and I just want to get some ideas. So any pictures you can share would be great.
    Thanks
  2. el Scotto
    el Scotto
    from Tracy, CA
    Sounds like you need to post pictures of your setup so we can see what's wrong with it.
  3. Gabe4223
    Gabe4223
    from texas
    Yup will do shortly...its a rear end of a 1980 S-10.
  4. mcknight05
    mcknight05
    from Ontario
    bump .I would also like to see different setups. im running a 9inch with a transleaf setup. but its hard finding good pictures of other setups.
  5. Goztrider
    Goztrider
    from Tulsa, OK
    My '29 RPU. '72 Pinto 7.5 rear, stock spring with leaves removed and main leaf shortened. Custom perches made to correct a building error when first modified. Rides nice and smooth.
    What we started with - rode like a deadman spring:
    What we did to correct the problem - VERY smooth now:
  6. Goztrider
    Goztrider
    from Tulsa, OK
    You can also check out the build thread shown in my signature for another setup. I mounted a 9" rear under my '29 Ford AA truck. It's unique and different, and quite ingenious if I do say so myself.
    Check it out if you want. I'm hoping to drag out the Dubble A in the next day or so and see about getting going on it again.
  7. Gabe4223
    Gabe4223
    from texas
    Awesome thanks looks great.
  8. Gabe4223
    Gabe4223
    from texas
    Here are some pictures of my rear end now. Coil springs thinking about adding shocks.
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    Run the shocks right up through the springs. ALL cars should have shocks front and rear but especially ones with coil springs. You'd think everyone would know that after seeing some of the old sleds riding around that after hitting a slight rise or slab seam bounce for a half mile or so until they settle down 'cause the shocks are broken, worn out, or gone altogether.
  10. Gabe4223
    Gabe4223
    from texas
    Thanks thats what I was thinking as well. I really appreciate your input.
  11. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    Yeah, you shouldn't be "thinking" about adding shocks, you should be in the process of adding shocks.
    Personally, I would take those coils and panhard bar out, and put a model a spring back in there.
  12. FC49
    FC49
    Don't have any pics of it, but the cleverest Model A rear susp I ever saw was designed by Howard Downing Junior who lives in the Syracuse, NY area. His full-fendered 1930 coupe has won awards everywhere. (See photo).
    His suspension design has bellcranks and horizontally-mounted coil-over Penske shocks and gives ample travel in a limited space. I'm sure someone, somewhere has photos of it. Downing is an auto engineer specializing in suspension designs. His bellcrank set-up was featured on the Tucci-built grand prize car at the
    2003 Syracuse Nats.
    Here's Downing, Jr's coupe. I'm not certain he still owns it. I took the pic in 2007.
    Frank C.
