What tail lights look good on a 56 Stepside Chevy ?
Discussion in 'The Hokey Ass Message Board' started by OLD SWEDE, Jun 16, 2011.
  1. OLD SWEDE
    OLD SWEDE
    The tail light lens are becoming clear, on my driver. So wondering which replacement light might look good on there .. The lights mount off the side of the box, so should be a contained unit . Wondering if there is a light that could be mounted from another car, or truck, that might give it a custom look ?
    If you have any ideas or seen someone else do it,, could you attach a pic ..
    JEFF
  2. Black_Sheep
    Black_Sheep
    I cut down some 60-61 Chevy p***enger car lenses to fit the '58 bezels, if you want more details shoot me a PM...
  3. DrJ
    DrJ
    BlackSheep,
    I have a stepside too and would like those tail light details also.
    Can you post them here?
  4. Black_Sheep
    Black_Sheep
    Swapping the lenses is pretty straightforward. As I said, the OD on the lens needs to be reduced so it will fit. After marking the new lens I chucked a burr in the drill press and freehanded it. The retaining screw tabs on the bezel also need to be removed. A cutoff wheel seemed to work better than a snips due to the contour of the bezel. A bead of calk and a small screw through the bezel at the bottom holds everything in place.
  5. DrJ
    DrJ
  6. D-man313
    D-man313
    im putting 37 ford lights on my AD, idk how it would look on your 56 but always an option.
  7. hotdamn
    hotdamn
    mount 49/50 merc lenses down low on your fenders!
  8. propwash
    propwash
    from Las Vegas
    restore the stockers....IMNSHO
    dj
  9. czuch
    czuch
    from vail az
    Black Sheep,,,,,,,,pm sent
    Thats sooo durn cool
  10. jacksonfivelab
    jacksonfivelab
    from Austin
    I did this. A bit cliche, but i like them.
  11. plymouth1952
    plymouth1952
    when I was a kid ( no smart *** remarks ) we had a guy put a set of 60 chrysler in the fenders looked real sweet.
  12. TheTrailerGuy
    TheTrailerGuy
  13. hershambob
    hershambob
    from reids rod parts
  14. Deuces
    Deuces
    How about some "frenched in" '59 Caddy lights???.. 2 per side..
  15. 57tailgater
    57tailgater
    from Georgia
    I prefer restored originals but a couple of other options are '39 Ford teardrops in the fenders or early '30's Chevy car tailights (pic below). '37 Chevy attached to the stake pocket would work too. NO LED's pleeeeez!! :cool:
  16. Here's mine. They are turn signals off a Harley. I just replaced the orange lenses with red ones. Lenses cost me $8. The lights were free! Can't beat that.[​IMG][​IMG][​IMG]
  17. napa has a led bullet on the rack
