Name that differential
Discussion in 'The Hokey Ass Message Board' started by pishta, Jun 27, 2011.
  1. pishta
    pishta
    from Tustin, CA
    Im picking up 700lbs of older 3rd members from a guy and cant ID half of them. figured you guys run the spectrum of badge fans so..some have no casting numbers at all on them so Ill post pics tomorrow night. Looking forward to some answers, or guesses? :confused:
  2. chaddilac
    chaddilac
    Uh 12 bolt?? :rolleyes:
    Should we go ahead and guess now? :D
  3. propwash
    propwash
    from Las Vegas
    uh..56 Ford, 48 2½T GMC, 59 Buick wagon, 54 Willys M38, 66 Merc full-sized, 62 Dodge, 1917 Herkimer HyDrive, 1944 Mack 2spd....how am I doing?
  4. Oh oh ...that's a 6-ton Timkin out of a 1942 Brockway wrecker......pretty rare.
  5. squirrel
    Thanks for the warning, although it's really not necessary. Make sure the pictures are clear, in focus, and show the whole thing from a couple different angles. Also be sure to offer a prize, cash works well.
  6. pishta
    pishta
    from Tustin, CA
    Well, I know you got one right, maybe 2. Well see tonight. 62 Dodge 652 casting (superceded by more popular 741 casting)
  7. pishta
    pishta
    from Tustin, CA
    OK, got 6 and I know 3 so here are the other 3: only casting shown is on the twins.
  8. squirrel
    neat stuff, not what you'd find in one of the Big 3 cars that I'm familiar with.
    Have a look here....
    http://www.marxparts.com/transmission.htm
    there are several diff gaskets shown, you might find that the Hudson and Packard look similar.
  9. pishta
    pishta
    from Tustin, CA
    My old mechanic said the look like old Power Wagon or truck diffs. He said the truck diffs look "funky". The weird one is a 4.11 ratio. Got some info on the twins, sure are Chryco as they have the DPCD square logo on the gear set and maybe some dates? one says 3.36:1 #870307 8 18 41 277NU and the other says "FORMATE" 3.36:1 1122353 12 23 48 234AJ so, maybe '41 and '48 Dodge diffs. Other one is still mystery, but I did get a number off it 403121 and there was a yellow paint pen that said 41 40. Ill look those years up. Thanks for the responses.
  10. squirrel
    Interesting about the mopar ones...3.36 ratio in the 40s would probably be from a big car, like a Chrysler. DeSoto only went as low as 3.54 as an optional ratio, plymouth standard ratio was 3.90
  11. pishta
    pishta
    from Tustin, CA
  12. pishta
    pishta
    from Tustin, CA
    Ok, maybe I should have leaked this photo...[​IMG]
    Found it when I finally got the gear set unfroze. A little oil soaking helps break 40 years of shelf life. Thanks guys!
  13. squirrel
    So that's why the 9 bolt packard gasket looked so similar....
  14. pishta
    pishta
    from Tustin, CA
    Packard 4.1:1
