Hot Rods How would have you built this car in 1962?
Discussion in 'The Hokey Ass Message Board' started by Tugmaster, Jun 28, 2011.
  1. I'm building a 38 Chevy 5 window coupe. I want to build it as a hotrod and not a tail dragger. I've looked on the internet and found some of these hotrodded but they are all the 70's/80's billet barges. I'm trying to figure out what a guy in the early 60's would have done if he was bulding this car. I'm kind of thinking a nice rake, blackwalls with spidercaps, nerf bars instead of bumpers. I have a 283 and saginaw I am putting in it. I an planning on keeping the motor stock looking for now. Maybe adding a tripower if funds allow it later on.
    I know their are some folks on here that were actually around in the early 60's. (I wasn't built till late 64) Can you please share from the "old days"
    How it probably would have been built. Thank you for your time and inputs. Todd
  2. gnichols
    gnichols
    from Tampa, FL
    How about as a street racer? G***ers were very popular so a wanna-be street racer might be of interest to you, even if you didn't jack the front real high or do a straight front thing. Here is a pix of a buddy's old car, Dave Ehrmann. It had a scratched Hilborn set-up on the I-6. He won Indy nats twice with it in the early 60s. This is the only photo I have of it. Gary
  3. wingman9
    wingman9
    from left coast
    In the early to mid '60s (in my neck of the woods -Colorado) your car would have had steelies with a bit of rubber rake. Typically 670x15 front, 820x15 on the rear. In the mountains it would have to be lowered a bit because we had a lot of corners to go around. We usually ran a rear bumper, but no front.
  4. shoprat
    shoprat
    from Orange, CA
    High in front, big tires on the rear.Black or white steel wheels with blackwalls.
    Did a 37 and a 40 Chev for a friend. Hope u don;t have a knee action front end.
  5. Jalopy Joker
    Jalopy Joker
    yep, even the different years of the 60's had different trends-go with what you like-your car would have been Hot Rod or G***er style-color would be a big part of look (Orange, Yellow, Black,etc)-small block/4 speed (with Hurst shifter)very correct-chrome only on engine (Chevy orange), unless Vette valve covers-exhaust cut outs or dump tube headers- raised in the front if anything, not lowered -spider caps, not likely unless a custom-no caps or small caps-no whitewalls-big'n'little tires-reversed rear rims-nerf bars OK-no front bumper and tube rear bumper (to fill with ballast) OK too-hood sides on or off-black or dark brown tuck'n'roll interior-Moon type hard steering wheel (not sponge)-AM/ 8 track stereo-ETC
  6. Sounds like I am part way there. Motor is Chevy orange with script valve covers. Hurst shifter too. I am also planning cut outs but wanted to keep the rams horns .So your saying no rake? Just a small moon cap or cap and trim ring? Todd
  7. F&J
    F&J
    The only one I know of in eastern CT was built very close to your town.
    37 coupe, mostly weekend drag car but he did say it was on the street at some point. Built in late 50s, parked/last raced in 62.
    A friend and I had most of his goodies a few years ago. It was early Olds powered, LaSalle trans, Olds rear. All of the money went into speed stuff. He had 3x2, 2x4, 6x6 setups, multiple cam grinds.
    There were no fancy wheels in his stash, so it must have been steel wheels, one set of M&H drag slicks and he said "then he started really breaking parts" :)..I think he said that's why he parked it.
    Must have been straight axle raised up a bit, because there were homemade fenderwell headers with block off plates for street.
    I forgot the tach brand but it was special to run with the Ducoil dist.
    He still has the car but started to streetrod it a long time ago; sbc, IFS.
  8. I'm thinking you would be spot on for the Northern part of Calif. maybe if you were high dollar Americans or Halibrands. if not Chromies or black steelies.
    Not a lot of lifted cars running the streets in San francisco in '62. A lot of racked cars with black walls or white walls and cheaters or 9.00x15 bias plys on the rear. Some really progressive guys running 14s on the front and 15s on the rear. Nerf bars were king if you had a street brawler, dumos were also cool but not real common like in S Cal.
  9. bob308
    bob308
    where i grew up. some brothers built a 39 chevy coupe with a 302 gmc punched to 320. olds rear borg-waner 4 sp. car sat stock hight. later about mid 60's it got a 327 with 4 2bl. carbs. it had painted wheels later chrome reverse.
    a 38 was built with a 389 pontiac and 3 sp trans. stock hight.
  10. Thanks for all the great inputs. Like I said I am going for a hotrod more than a g***er. I guess in the early 60's though thing must have taken a turn towards the g***er/street racer style. I just don't want it to look like something from the 80s. Thanks again, Todd
  11. 270283
    270283
    If I built it in '62 it would have been a 283 with the vette quads, Duntov cam, 3 or 4 speed with a Hurst, Heddman Hedders, cutouts, 55-57 4.11 posi, Traction Masters,stock height, with chrome reverse rims and Bucrons on the back. Probably would have been Honduras Maroon with a black and white interior.
  12. 550Coupe
    550Coupe
    I bought my 41' Ford convert. in 62'. 14's in the front 15's in the rear, wide whites, no front bumper, built flathead w/ 39' 3 speed, candy apple red w/ black & white tuck and roll and scavenger pipes hanging out the rear. If they weren't flat on the bottom they weren't low enough! That was an early sixties hot rod.
  13. squirrel
    I was still in diapers in 1962. But here's how another guy's Chevy coupe looked at the time.
  14. jcmarz
    jcmarz
    from Chino, Ca
    Watch American Graffiti and check out all the cool cars. That will give you a idea of how to do your chevy. And remember that not everyone had the money to build a magazine car.
  15. squirrel
    ....as an early 70s version of an early 60s car!
  16. scrubby2009
    scrubby2009
    Tried to find a picture of my dad's '32 Chevy sedan that he had in the early '60's, no luck yet. 2-tone metallic blue, reversed chromes with narrow whitewalls, maybe a little drop in the front, ran both bumpers and a 303 Olds with a Hydra-matic if I remember correctly. I remember him saying he traded it for the mythological "little old lady" owned '53 Merc hardtop, black roof over pale yellow. Get some pictures up, love those late '30's sedans!
  17. 50Fraud
    50Fraud
    '38 Chev hot rod in '62?
    Rake, 5-spokes, GMC I-6 (I liked old timey even then)!
  18. badshifter
    badshifter
    How did they do it back then with no S-10 frame swaps? Weird.....
    I'll dig out pics. I did a 38 4 door years ago. 235, 4 speed, Denman wide whites on steelies and slightly lowered in front. It was a FUN beater. Except for the knee action.
  19. Jalopy Joker
    Jalopy Joker
    yep, stock height, or slightly raised-straight axle cars with fenders were not lowered, unless customs-a tach with chrome housing-gl*** pack mufflers-ram horns-if running a alternator mount it low since they were still running generators-OK to have battery under hood-no Caddy air cleaner-14" front steel rims OK, but not wide ones-rear rims should not be wider than 8"-if must run electric fan put in front of radiator-Baby Moons OK, but not beauty rings-rims black, some ran white rims-chrome steel rims OK-most guys did not not have much money, so painted things like fire wall white just to look like magazine cars-diamond tuck upholstery OK-No electric windows/AC, etc-might want to upgrade to a later steering box for better handling-make sure brakes, etc in like new condition-keep it simple-check here, swap meets, craigslist, etc for deals on parts
  20. jcmarz
    jcmarz
    from Chino, Ca
    George Lucas did the car scene as a teenager back in the early 60s and A.G. is based on those times he spent cruisin the main drag. So the movie is a good example of what the car scene was like back in the early 60s. So if I was to build a car, early 60s style, I would study the cars in the movie to get a idea of how it was.
  21. 50Fraud
    50Fraud
    AG is a reflection of what George Lucas remembered about the scene in Modesto in 1962. The mere fact that the Merc and the '32 5W are scorned by most serious traditionalists shows just how well George was paying attention.
    No disrespect to George; he's a terrific filmmaker. He's no rod & custom historian.
  22. olscrounger
    olscrounger
    Stock height, black steel wheels-maybe babay moons, a little wider on the back, 283 with solids, 2-4's ,4 spd,Generator, battery where it belongs, rams horns with cutouts,tach on the column--as some have said--later steering box and better brakes.
  23. VonWegener
    VonWegener
    That was my first thought too. These Chevies were very popular at the drags and very successful.
    Thank you for posting that photo Gary!
  24. Buddy used to have one that was built in about that era - they put it on a Studebaker Lark frame. I think it was channeled a bit to give it some rake without messing with the suspension. When he had it, it didn't have fenders on the front but it came with a set painted in the same bright yellow, so it must have had them on at some point.
  25. badshifter
    badshifter
    Here is after one of the MANY rebuilds of that car.
  26. RDR
    RDR
    The hot '38 that ran around the syreets of Eugene in 1962 had a 302 GMC in it,steel painted wheels and Pontiac rearend....also a '40 Chevy coupe was grey primer,324 Olds,Cad Lasalle trans and Olds rearend,painted steel wheels and WW cheater slicks
  27. Sheep Dip
    Sheep Dip
    from Central Ca
    I vote for the G***er look being's it a 5 window coupe, all those old cars from the g***er wars era were great to look at.
  28. Normbc9
    Normbc9
    The I-6's are still eating their way out at the strip. I see one from Oklahoma that when they show up they take the Trophies home. There is another up in Sturgis, SD that isn't a slouch either. I have one with some Clifford performance items on it and it stays with the big dogs on the highway. There is another here locally that shifts at 7,700 RPM and it is staying together too.
    Normbc9
  29. gnichols
    gnichols
    from Tampa, FL
    No problem, just trying to stir the bucket and offer some ideas. If you happen to have a copy of G***er Wars, you can look him up. H/G is a minor deal, but he beat everyone in his cl*** at Indy, twice just to make sure.
    Some of the other suggestions sound interesting, like loosing the front bumper, a very slight nose high rake, bigs n littles but vintage slicks only for vintage drags or a car show. Gary
  30. S.F.
    S.F.
    you should start gathering old rod and custom and hot rod magazines from the early 60's before you turn a wrench on it. Read them, study the pictures. Read the adverti*****ts to see what was available in 62
