Hot Rods Who's running a 383 small block chevy
Discussion in 'The Hokey Ass Message Board' started by pokey, Dec 2, 2010.
  1. lotus
    lotus
    from Taft, CA
    how was it off the line? gutless or some what lively?
    Here is a pic of mine. re-doing the wires.
    HP KB pistons
    weiand stealth intake port matched to the heads.
    holley 3310 780CFM carb
    pertronix flamethrower HEI
    world sportsman 2 heads
    elgin E1019p cam
      67 KB
  2. usmc50lx
    usmc50lx
    from St.Louis
    And how are we gonna settle our score if you do that mister??? :D:D-Paul
  3. DirtyJohn
    DirtyJohn
    HAHA saw that huh?! I'll be there Paul! I just gotta build something else. Just selling the engine by the way... :)
  4. willeys41
    willeys41
    from seattle
    with a 4 barrel,right out of box onto the strip.114MPG 12:63 raced for 2yr and put the 32 plymouth 4 dr back onto road.Been driving with no problem now for 6yrs.Never burn a drop of oil.Pulled the front out the ground at the strip.Dave
  5. BulldawgMusclecars
    BulldawgMusclecars
    I put one in for a customer recently (OT '69 Z/28). The Z still had the M21 and original 12 bolt with 4.11s, and felt decent with the motor that was in it (not the original 302), but when the customer built a "correct" 302 he asked me about making more power without being too obvious (no huge cam, stock Z/28 heads and intake, etc). So, we built a 383 stroker, and he's been very pleased with it!
    I also had one in an OT '97 Camaro SS (LT1), and it had 4.10 gearing with the 6 speed. 2300 RPM at 85mph, and pulled like a freight train all the way to redline.
    Frankly, I wouldn't build a 350 (or large journal 327) anymore...unless you are spinning the 350 to the moon, and have the valvetrain to support it. The 383 is going to make more power, and for about the same price.
  6. DeepSea Fish
    DeepSea Fish
    Why not just leave that crank in the 400 block, and take advantage of the 20+ cubic inches with the 4.125 bore?
    Is it because the 400 stuff is getting hard to find? Just wondering?
  7. Mac30
    Mac30
    try to find a good 400 block. they are scarce and when you find one they are typically twice to quadrupal the cost of a 350 block.....
  8. swade41
    swade41
    from Buffalo,NY
    So what cubes does a .060 over 350 block with the 400 crank make? My block wa at .040 but had to go to 60 over to clean it up.
  9. chevyben
    chevyben
    from washington
    I have one in myt pulled it from my 53 just pulled it from my vega when I traded it. It made 500+ hp on the dyno in my truck befor the NOS.
  10. Chevy54
    Chevy54
    from Orange, CA
    Im runnin a 383 w 700R4 and it goes really well..great torgue and revs like a SBC should! 2800 stall in a custom built trans w a 3.73 currie 9". Rev limiter set at 7k and barely touch it...cruises down high way 75-80 and low revs! Nothin but fun w 400 plus HP/Trq!!
  11. ULRICK
    ULRICK
    from Texas
    Im about to build one, gonna run it with a 700R4 and 9" Rearend with 3,73 Gear.
  12. bill3337
    bill3337
    I've got one in my '33 Ford coupe, fairly modified. Dyno'd out at 517 hp, running T5 with 4.11 rear gears, runs low 12's with street tires, doesn't idle worth a ****, but it's worth it!
  13. Flingdingo
    Flingdingo
  14. lotus
    lotus
    from Taft, CA
    I finally got the motor in the 63 chevy truck and got the cam broke in. I pulled it out of the shop and around the block to turn it around and I tapped the gas once and the truck felt like it wanted to pull the front tires off the ground. Here is a quick vid of it. I need to figure out what is causing the noise at :08...think the pulley on the water pump needs one shim removed.
    <iframe ***le="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/uNPIhkUxy20" frameborder="0" allowfullscreen></iframe>
  15. Bad Daddy
    Bad Daddy
    Correct. That's what I was running in my o/t '72 Vega. That engine was stout to say the least.
  16. mgtstumpy
    mgtstumpy
    Yep, 383 going in my 46 Olds, lots of torque for a big heavy car at 3.5k lbs. Add some ported alloy heads, roller cam and lifters along with a 6x2. Should be fun when dialed in on the dyno. Add a fresh 700R with 2.5K stall convertor and 3.5:1 rear end. :D
  17. Bad Daddy
    Bad Daddy
    What was it they say about opinions. . .
  18. outlaw256
    outlaw256
    ive got one in my 53 ranchwagon and gonna build another one for my 41 willys. me like. these damn things will roast back tires just playing and pull a house down arond your ears for fun.
  19. c-10 simplex
    c-10 simplex
    Let's price out a homebrew, if you would? Include labor and machine shop work. Target hp/tq is 425/450 respectively----same as the zz383 crate. Feel free to change any of my suggestions because i'm not an engine person, just trying to get zz383 numbers cheaper if possible.
    Summit remanufactured 383 block $650:
    http://www.summitracing.com/parts/SUM-150100/
    i know you can't just drop in the rotating ***embly without checking things out and if nessesary do machine work, but it appears that the most of the major machine work has been done.
    **** rotating ***y # 1-47010---$1600:
    http://www.summitracing.com/parts/SCA-1-41710/
    This kit has forged crank--same as the zz383. i don't know which is better I beam or H beam rods, but the zz383 appears to have H, so i went with that.
    Not sure where to take it from here. i want aluminum heads because the zz383 has them. i am not 100% opposed to iron heads but they better be very cheap.
    Also, if it makes a difference in component selection, i plan on running a tunnel ram because i have the hood clearance.
  20. Mickm
    Mickm
    I'm running a 383 (460 hp) with a 2004r and 323 gears.
    These are great powerplants.
    Cheers!
    Mickm
  21. brian55lvr
    brian55lvr
    from ma
    this is what im running-----does real well on the street---http://www.youtube.com/watch?v=0u70SLRn5uw&feature=related
    camaro has a built 396 big block
  22. lippy
    lippy
    from Ks
    I'm buying used running 454 BBC's here for 500 bucks. Cheap power. Heavy, but cheap. Lippy
  23. c-10 simplex
    c-10 simplex
    1) ok let's not.
    2) How heavy the big blocks? What about with aluminum heads?
  24. GAOldsman
    GAOldsman
    from Perry, GA
    '35 Dodge Coupe 383 stroker around 450 hp with a 700R4 4500 stall and 373 gears out back.
  25. elvi411
    elvi411
    I have one in my 53 burns the tires off! I have been sideways around corners, last week almost hit a pole. Fu*k
  26. bulletproof1
    bulletproof1
    from tulsa okla
    i just put one in my 53 ford 2 dr sedan,,350 30 over 400 crank 6" rods dart 215 heads,solid cam, hurricane intake, 750 holley,350 turbo with 3500 coan convertor ,9'' 355 gears and street tires.with no tune it went 12:75 @105 mph...it was spinning the tires pretty bad...
    just dropped in a 4:56 gear and a 29x9 slick..hope to drop into the high 11s.. this motor spins super fast..
  27. nanos1932
    nanos1932
    I got one.....with a 671 and 12psi through AFR heads, glide and 4.56's make it real fun on the street.
  28. Graham M
    Graham M
    from Calgary AB
    Yeah? and hows that fuel economy?
    BBC are great for big HP/TQ with a small investment, but most I've seen **** up any savings in terms of how much gas they drink quite quickly.
    Outside of a drag racing environment, I'd never touch a BBC for anything.
    For my '38 Chevy truck Im building a 500hp (ish) 383, with a TKO600
  29. 3banjos
    3banjos
    from NZ
    Yep, we all like a bit of torque. Fully rebuilt with an old look. Fired up 1st time, straight out rams, sounded frigg'n great. Few minor adjustments, rockers etc, and water pump decided to **** itself. Dry for too long ah..
      263.6 KB
  30. barryvanhook
    barryvanhook
    from Mesa, AZ
    Got one in my 69 truck ... it fills the cab with tire smoke if I let it. Or it is as docile as a lopo 350.
    Barry
    it makes me giggle
