1964 olds 394 vacuum hoses
Discussion in 'The Hokey Ass Message Board' started by skyrocket, Jun 28, 2011.
  1. skyrocket
    skyrocket
    from minnesota
    i need a picture of a motor to see where the vacuum lines hook up. any help? thanks
  2. rougebeats
    rougebeats
    2 bbl or 4 bbl?
  3. skyrocket
    skyrocket
    from minnesota
  4. rougebeats
    rougebeats
    getting some pics out of the archive now...hang tight for a minute
  5. skyrocket
    skyrocket
    from minnesota
  6. rougebeats
    rougebeats
    I thought I had more after the 2bbl-4bbl conversion, but this is about it. If you have any questions on where things go, just let me know. The 4bbl setup isnt much different than that of a 2bbl setup.
  7. rougebeats
    rougebeats
    If I can recall correctly, there should only be three lines off of the carb that are vaccuum.
  8. skyrocket
    skyrocket
    from minnesota
    cool thanks a lot.
  9. skyrocket
    skyrocket
    from minnesota
    mine seems to have two ports one on the right side and one coming out of the back. where does the one on the side go too? cant really tell. The back one looks like it goes to the vacuum advance on the dist.
  10. rougebeats
    rougebeats
    There is one on the back of the intake that goes to the brake booster as well. Also, 1 will be coming off the carb to the breather. Im pretty sure the one on the side goes to the breather
  11. skyrocket
    skyrocket
    from minnesota
    ok yeah the one on the breather i don't have hooked up
  12. skyrocket
    skyrocket
    from minnesota
    hey do you still have that exhaust manifold, i found your add on cl***ic oldsmobile? i know its a year old but still thought i would try.
  13. rougebeats
    rougebeats
    I sold it when I sold the car last year. You can find them from time to time on here in the cl***ifieds or on the E site. They can be a bit pricey since they arent around often. Good luck.
