32 ford frame rails
Discussion in 'The Hokey Ass Message Board' started by 48fordnut, Jan 15, 2008.
  1. 48fordnut
    48fordnut
    I need some info.,and have done a search. I need to know some good recomendations for a 32 frame . I want it to have the reveal, and possibly be pinched for a model a body without fenders. any one have any good choices, or recomendations? thanks, jim.would like something in the south east.
  2. captainflight
    captainflight
    So Cal has an "A" V8 frame ready to go. Honest Charlie is dealer for them.
  3. many good `32 frame builders , some even on here so i will let them speak up ...but whatever you choose do not go with TCI. the frame rails are made of welded pieces and the reveal is all wrong. looks like ****
  4. buford36
    buford36
    from Maine
    Vaphead at Rileys !!!
  5. KATFISH
    KATFISH
  6. revkev6
    revkev6
    from ma
    if it's a 30-31 body, you don't need to have it pinched. if that helps....
  7. 392_hemi
    392_hemi
    Got mine from Kiwi Konnection. Highly recommend them.
  8. vintagehotrods
    vintagehotrods
    Kiwi Konnection in Bakersfield. The best frame for the money (starting at $1950) and is all tig welded. You won't regret using one of theirs.
    Here's their website: http://www.kiwikonnection.org/
  9. narducci
    narducci
    Build your own ! I will have about $400 in mine when its done.
  10. Pretty fly frame jig, Narducci.
    I got the front half of some '32 rails here on the H.A.M.B. for $75. It's going to be channeled anyway, so I'll make the rest out of box tubing.
  11. lockwoodkustoms
    lockwoodkustoms
    Honest Charlies is who I got my 32 rails from. Got them at Hershey and they were priced right.
  12. kennedy
    kennedy
    from TN
    If your looking to buy your own frame rails and build the frame yourself. Go with a set of ASC rails. Thats what I used...
  13. 54BOMB
    54BOMB
    Kennedy, your car rules.
  14. gooseta2
    gooseta2
  15. lockwoodkustoms
    lockwoodkustoms
    What are the tire size you have there on that there Coupe? .........................:D
  16. The Engineer
    The Engineer
    what rear cross member did you use in this frame? I love the way it sits....:D
  17. el Scotto
    el Scotto
    from Tracy, CA
    I just picked up a set of ASC rails, too.
  18. ibarodder
    ibarodder
    J W rod garage... call them all and tell them your going to buy, so whats their best price.
  19. The37Kid
    The37Kid
    I plan to buy my '32 rails from J.W. Rod Garage. Wonder if they or a dealer will have a pair at Hershey in October?
  20. Henry VIII
    Henry VIII
    from Tulsa OK
    Pete & Jakes, Peculiar Missouri. They do excellent work and are a pleasure to work with. The attached example was done for my 32 Tudor.
  21. 392_hemi
    392_hemi
    Thought they changed their rails so that they are narrower than normal and full width only if you weld on the boxing plates. Been a while since that was discussed, but you might want to check before you buy them.
  22. lil_screamer29
    lil_screamer29
    ive been looking at getting the brookville frame, has anyone ran that one yet
  23. junk yard kid
    junk yard kid
    I looked a the brookville frame at the roadster show. It has sharp edges. i didnt like the way it looked.
  24. krylon32
    krylon32
    from Nebraska
    I started using JW Garaqge boxed rails after my welder of 10 years moved back to his hometown in Kansas. He had been boxing my ASC rails for many years. I'm just getting lazy so the JW rails were the only option and they have been working out good. I just put my 32 delivery body on one of my stg III ch***is and it fit fine.
  25. bp1971
    bp1971
    from Fresno, CA
    I am using ASC rails from Kiwi Konnection in Bakersfield, CA and I had them pinch the frame for me so it would fit my '29 roadster. I put in the cross members and boxing plates, which came from them too. They were great to deal with and I think that they use ASC frame rails as well.
  26. Call Alan at Johnsons Hot Rod Shop,256-492-5989 He KNOWS 32 frames and will build you what you want.
  27. billthx138
    billthx138
    So-Cal's A-V8 frame was the ticket for my Model A. It was designed for the 28-29, however it is perfect fit for the 30-31 if you want a channeled look.
  28. alchemy
    alchemy
    Yes, the only way JW Rod Garage offers their rails is with the small notch for the boxing plates. Just asked him a couple weeks ago about this, and he said he'd have to write a new program to trim them in the original Ford dimension. He did tell me that if I'd buy ten sets, he do it for me.
  29. erlomd
    erlomd
    Must agree, I went to their shop couple years back and it was top notch quality stuff all tig welded and the owner is one kool cat. He will create anything you want on the frame.
