Hot Rods Cheap Hot Rod axle
Discussion in 'The Hokey Ass Message Board' started by hotrodnomader, Jul 2, 2011.
  1. hotrodnomader
    hotrodnomader
    Was working on my beater 71 Ford f100 the other day. Happened to notice the front axle. Rather attractive looking and it has a slight drop to it already. Should be able to unbolt that coil spring ***embly and bolt right on a buggy style spring. The stock hubs are also 5 on 5 1/2" so old wheels would bolt right up. If somebodys building a hot rod and after a cheap drop axle with newer brakes it would be a great alternative.
  2. Hot Rod Willys
    Hot Rod Willys
    from Ohio
    Isnt that a twin I beam?
  3. Bigjake
    Bigjake
    Yeah twin I beam
  4. wizzard23
    wizzard23
    I'd like to say "dumb ***" about now.
    zzford likes this.
  5. el Scotto
    el Scotto
    from Tracy, CA
    x2 :D
  6. scrap metal 48
    scrap metal 48
    I'm afraid it's a 2-piece axle and wouldn't work......
  7. Mr48chev
    Yep, big, bulky, heavy and ugly. Not really what you want on a real hot rod HRM.
  8. aaggie
    aaggie
    Pre paid and pre planned funeral arrangements would help your family in it's coming time of need.
  9. Ned Ludd
    Ned Ludd
    And no, they can't be bolted together with u-bolts to make an axle ...
  10. squirrel
    Another of ford's better ideas.
  11. wizzard23
    wizzard23
    I call em "Twin I Tire Eaters".
  12. Actually, they probably could be, just not a very good idea. Don't say it too loud or some rat rodder will try it.
  13. KrisKustomPaint
    KrisKustomPaint
    I'm pretty sure Model A axles are still relatively cheap and plentiful and a whole lot cooler than a twin I beam.
  14. Ned Ludd
    Ned Ludd
    That possibility occurred to me just as I was typing ...
  15. flamedabone
    flamedabone
    The short answer is no, you wouldn't want to use any axle parts off a twin I beam front end.
    But, don't let us beat on you too hard, at least you are keeping an eye out for stuff that might otherwise go unnoticed. Sometimes we get hung up on all the stuff you "can't" do.
    -Abone.
  16. Old&Low
    Old&Low
    Hey hotrodnomader, before you let 'them' "beat on you too hard" you might want to have them look up "Flaming River," a company that's made a fortune on their twin I Beam front suspension called "Dominator." It wasn't such a 'hair brained idea,' for an unconventional dropped front end and, evidently, Rod and Custom Magazine didn't think so either. http://www.rodandcustommagazine.com/techarticles/0808rci_beam_tube_axles/photo_18.html
  17. Unkl Ian
    Unkl Ian
  18. AAFD
    AAFD
    from US of A
    Flaming River made a fortune on this? When was the last time you saw one of these hokey *** axles under a car? I don't think I ever have. And if I missed it, it's probably because it's under some easter egg cookie cutter streetrod that I walked past without flinching. Wow... they paid for adverti*****t in a magazine and got a biased article written about their product! That must really mean it's a great idea for a part! Give me a break.
    Obviously this kid saw the underside of the truck and didn't realize there are two separate axles of the Twin I-Beam suspension. No big deal.
  19. Ned Ludd
    Ned Ludd
    I agree with these guys. Nothing wrong with seeing new possibilities in stuff: just make sure you look at the other end :D
    In fact the Ford twin-I-beam (and the Flaming River version) gives better geometry than the systems that pivot in the middle - including Allard's. Specifically, less camber change and a lower roll centre.
  20. second_floor_loft
    second_floor_loft
  21. Old&Low
    Old&Low
    The same article mentions Fatman Fabrication's version of splitting the I Beam also. Both of these guys came up with innovations long before Rod and Custom, or any other magazine, decided to do a story on them. I've seen some wild, and GREAT fabrication ideas coming from many members of this site alone! Don't be so quick to rudely discount this "kid's" ideas. It's the same kind of improvisation that gave us the old cars we so dearly love to hot rod and modify.
    05snopro440 likes this.
  22. Well not bolted but couldn't they be riveted? :rolleyes:
    hotrodnomader
    Lots of old truck axles get used those from a parallel leaf system work real well with a quarter eli system. But Ford used twin I beams from the early to mid '60s until they figured out that they didn't work worth a damn. Try looking at an older truck.
  23. A Rodder
    A Rodder
    Ford used a solid axle thru 64, starting in 65 on half ton trucks they switched to twin I beams. I believe they still used them all the way thru the early part of the last decade on half ton trucks. On earlier 3/4 and 1 ton trucks as well as some four wheel drives solid axles were used.
  24. SmoKerch
    SmoKerch
    JB Weld?
  25. rigid_bobber
    rigid_bobber
    It is threads like this that made me quit posting on the HAMB (my last post was almost 2 years ago). I know I'm not missed, I never had much to say. All I know is some old Pontiac ****. I am young(er) and pretty new to hot rodding. You ask one question that someone thinks is "stupid", misidentify one thing, or make a suggestion (such as this one) that people don't like and you get beat down for it.
    This place is nice to lurk and look at pictures, but as a community it is pretty ****ty. You eat your own over minor things. Try teaching the new guys something rather than taking them apart. You old *******s are going to die someday and then the hot rods will be left to the Cobalt SS crowd. I haven't posted in almost 2 years because of this ****. I was new to hot rods and wanted to learn. It turns out this isn't a good place to suggest things or ask questions.
    Fire away at me. I only stop by once a week or so to see if there are any pictures I want to look at anyways. I do read threads that look like they may help me out. I am trying to build a car on a budget and learning as I go. It won't be perfect and it may not have all the coolest **** on it but it will be safe, run good, and be fun to drive. Afterall, that is what hot rodding used to be about.
  26. 55chieftain
    55chieftain
    Cheap axle yes, Hot rod axle NO
  27. Scarebird
    Scarebird
    Alliance Vendor
    from Moita, PT
    If you were to do something like that the Rangers 2WD's had TIB's - much narrower track and disc to boot.
    IIRC they are cast steel, so could be cut/welded to fit but camber may be WAY off...
  28. Good damn thing you waited until 2007 to join in the fun. Back in the late '90's it was dog-eat-dog here.
    Seriously. I even left for a time, before growing a pair and leaping back in. But that was a decade ago...
    Now we have the touchy-feely HAMB. And YOU complain about THAT.
    Cosmo
  29. mastergun1980
    mastergun1980
    from Alva OK
    Twin I beams are remarkably tough frontends. But they are wide, heavy, and tend to wear tires out fast.
  30. moefuzz
    moefuzz
    Ford used twin I beams thru the 70's and 80's and if the king pins are greased regularly, they will last indefinitely and haul tons of weight which is something that the compe***ion can't say.
    Ball joints and A arms are for the cross town sissy compe***ions light duty girly boy car ride pick ups.:rolleyes:
    The twin I beam on my 79 has made 425,000 miles and there is no issue with tire wear unlike what the people who have never driven one will tell you.
