421 Tri-power Redline Question
Discussion in 'The Hokey Ass Message Board' started by Al T, May 30, 2011.
  1. I've got a 1966 421 YJ Tri-power engine in my 64 GTO. Could somebody tell me what the redline is for this engine. I tried, but Google ain't my friend on this topic.
    Thanks in advance.
  2. Motornoggin1
    Motornoggin1
    I wouldn't spin it much faster than 5500, maybe 5800 rpm. Depends on what kind of shape it's in. It might make 6k a few times, but it's not making power up that high anyway and it's not worth hurting it IMO.
    My stock 421/428's liked to shift @ 5100-5300 as power really drops off fast beyond that.
  3. propwash
    propwash
    from Las Vegas
    find a 66 full-size Poncho factory tach for that engine....on Ebray...pontiac forum...they'll usually mention the redline...or you can "enlarge" the photo.
    dj
  4. If it's like the tach in my '64, the redline is adjustable.
  5. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Not more 5200-5300 rpm's!
    Pontiacs are not high rev motors.
  6. d.reese
    d.reese
    I think mine is all green lined to 6000, but Ive never pushed mine over 4800:)
  7. Deuces
    Deuces
    Ditto!!!!!!!!!!!!!
  8. Motornoggin1
    Motornoggin1
    421's had the Armasteel crank and good rods. The HO was rated at 370hp(353hp)* @5200 rpm. They can safely go higher than that if they are in good shape. I would put the redline at 5500, but there is no need to spin them faster.
    *depending on head casting
    EDIT, found some literature that states max shift point of 5900 rpm for the HO. But again, there is no need to go that high.
  9. KoolKat-57
    KoolKat-57
    from Dublin, OH
    YJ is the designation for the 353 HP 421 w/automatic HP rated at 5200 rpm's after that your just pushing your luck!
  10. Deuces
    Deuces
    There's not too many of these 421's or 428 motors around like the belly ****on small block chevys... I'd keep the revs below 5000 that way it will live longer.. I'd hate to see one of those get destroyed.. :(
  11. 39 Ford
    39 Ford
    I used to shift my tri power GTO at no more than 5200. Why spend lots of cash on a rebuild when you can avoid it.
  12. treb11
    treb11
    Pontiacs are torque motors, not rpm motors.
  13. mart3406
    mart3406
    from Canada
    Unless your 421 happens to be a rare and
    valuable 'Super-Duty' version.....two words
    for you to think about when you're winding it
    up - "CAST RODS". With standard, 'non-SD"
    cast rods' Pontiacs shouldn't be spun past
    5500. And if you're running a stock Pontiac
    cam - even one of the "good" 'O68' cams
    - in a 421, you probably won't make any
    more power spinning it beyond 5000-5200
    rpm anyway. Low and mid-range torque
    (m***ive gobs of it!) is your friend with this
    motor...not high rpm horsepower.
    Mart3406
  14. Jingles
    Jingles
    I always shifted my '64 389 tri power at 5500-5800 and I never had any problems with it. Two of my friends had '65 GTOs with tri power 389s and they shifted at
    about 7000 but they were running open headers and I think they were running
    310 degree Isky cams. Back in those days, the factory rated the horsepower of
    muscle cars at about 5000 rpms in order to show a lower horsepower rating than
    what the engine actually made; that was done to help the owners get lower insurance ratings and to place their cars in a lower cl*** at the drag strips.
