Folks Of Interest Fenton SBC Headers now Reproduced!
Discussion in 'The Hokey Ass Message Board' started by CTaulbert, Feb 20, 2009.
  1. Dammit! I didn't even think about that! I made these instead.
  2. Rookie mistake!:D
  3. Haha! I knew I should have waited!
  4. dsr_54
    dsr_54
    How do they sound with four pipes? Do they have a different sound?
  5. mgtstumpy
    mgtstumpy
    Bought a set of repops for my 46 Olds sedanette. Adding some 'Fauxsmobile' rocker covers, Powergen alternator and a 6x2 crossram. Can't wait to dummy fit everything.
  6. MAD MIKE
    MAD MIKE
    from 94577
    Hmm... Is the center still divided? Or does it allow for crossflow of middle cylinders?
    Would be neat if you could pipe it for that flat crank sound.
  7. I have a question on these. Can you run them using conventional style front motor mounts or do you need to use the Hurst style mount that goes all the way in the front of the engine? Thanks, Todd
  8. I am running a Hurst mount but any front mount would work.
  9. Here you go Tug. I even got some Rebel Wire in the pic for you, ha!
    Sent from my iPhone using TJJ ****a!
  10. Hey, cactus, I can hardly breath after looking at that picture of your Chevy V-8 !!
  11. Boones
    Boones
    from Kent, Wa
    WOW, I love the look. just the right color orange and vintage valvecovers
  12. Thanks fellers!!
  13. That's sweet as hell. Not just the Rebel wire part either:D. If you run a hurst mount though you have to run an electric fuel pump. Correct?? Interested in selling the rams horns you had on there? Todd
  14. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    You can notch the hurst mount or I would just suggest making your own so you can get the engine at the height that you'd like with no spaces. I used all the original Hurst kit stuff in mine so I needed an electric fuel pump....which I don't mind only because I am a nit picking ***hole and hate how the fuel pump lines have to run from the front to the other side to meet up with the carbs.:D
  15. With the right Mech pump, some spacers and a touch of grinding you can run the Hurst style mount with a mechanical pump
  16. Thanks Todd. If I am not mistaken, ***us used a Hurst mount and mech pump in that red roadster he just built.
    Hindsight being what it is, I would have used my stock front mounts and mech pump were I to do it over again. Because of those huge mounts I made off the frame a mech pump would not fit without some serious mods. Oh well, live and learn I guess. I'll get back to you on the ram's horns.
    M to the I to the k to the e
  17. Rpmrex
    Rpmrex
    from Indiana
    Can you run these with a vega box?
  18. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I would say so, especially if you haven't located the steering box mount on the frame yet.
  19. HEATHEN
    HEATHEN
    from SIDNEY, NY
    If by "conventional", you mean the stock '55-'57 mounts, yes.
  20. Thanks Mike, I'll do a search for his roadster. Todd
  21. hawleywood1
    hawleywood1
    I found a pair on Fentons. How can you tell if they are real. How much are they worth? 2k or more..
    Thanks.
  22. bradberry00
    bradberry00
    Does anyone repro. the Y-Block Fenton headers??
  23. BigThree
    BigThree
    If ran with 4 exhaust pipes, what size would you run with a mostly stock internal 283?
  24. The outlets are 1-1/2". I ran mine 2 into 1 and then 2" out.
  25. hudson hot rod
    hudson hot rod
    Does anybody have more pics of these beauties installed? Also are the 200 repops all sold?
  26. mgtstumpy
    mgtstumpy
    Here goes.
  27. sololobo
    sololobo
    JUmpin jawbreaker, that is awesome. I would go for those in a minute. At $300.00 that is totally affordable. I had never seen a pair of those knockouts. Thanx for the news! ~sololobo~
  28. Six Ball
    Six Ball
    from Nevada
    I just talked to Patrick and they still have these and he quoted me $300. Better for me I got one side of a busted set for $150. With a little work it will go on my 153 Chevy 4 cylinder!
  29. mgtstumpy
    mgtstumpy
    Forgot to mention, I'm using side mounts and made similar LS series to SBC mounting plates to clear exhaust outlets on my 383. I moved mounts back the width of mount, around 3". Only reason was to clear exhaust. Hurst style mount wouldn't fit with low mounted AC & PS. Also had to fabricate a generator bracket to bolt onto headers with LWP. 2012-03-18 14.35.20.jpg 20130108_182949.jpg
