torque tube/tranny
Discussion in 'The Hokey Ass Message Board' started by Heavychev, Jul 8, 2011.
  1. Heavychev
    Heavychev
    from Radford,Va
    Is it possible for the gear oil in the ****** to travel through the torque tube on an enclosed drive setup,this is a 3 spd in a 48 chevy car,also will a 39-40 chevy 1/2 ton 3 spd top loader bolt right up in this car.I appreciate any help with this,as my car ****** seems to be wanting to hang up in two gears(OUCH) hadn't broke anything yet but somethings not right.Thanks
  2. terryble
    terryble
    from canada
    Yes, especially if the old Chevy was a little nose high and/or parked on an incline a lot, as kids we would regularly drain the excess fro th dif and readd it to the ******. Thanks for the memory, I had a good giggle about that one! As to the ****** question some will and some have a different bolt spread on the gear box but you could use the bell housing to make it work.
  3. K10
    K10
    Please look up "Okie bushing" to remedy your problem. Jim Carters and others have them. This will eliminate the need to remove the original failed bushing. This just goes on top.
  4. 49ratfink
    49ratfink
    I think I might be looking at the linkage. does your car have that vacuum shift deal on it??
  5. Heavychev
    Heavychev
    from Radford,Va
    Thanks for the replies,my problem turned out to be low on gear oil,put in maybe almost a quart and moved the car back & forth a few times and that solved the problem as for the va*** ***isted shift I had already removed that thinkin it was the culpret,Drove it today and it did just fine,the ole chev purred down the road,my brother inlaw has a 39-40 1/2 ton with a 3 spd top loader and said I could have it so I'm gonna get it and look it over,it might make a good replacement some time down the road.again Thanks a bunch,Randy
